Introdução
Use this guide to remove or replace the back cover on a Motorola Moto X Pure Edition.
O que você precisa
Prepare an iOpener and heat the back of the phone along its right edge for about five minutes. This will help soften the adhesive securing the back cover.
Hold a pair of pointed tweezers closed, and insert them into the small hole on the edge of the back cover near the SIM card slot.
Use the tweezers to lift the cover up slightly, and slide an opening pick into the gap between the cover and the frame.
Prepare an iOpener and heat the back of the phone along its left edge for about five minutes. This will help soften the adhesive securing the rest of the back cover.
Carefully pry the cover away from the phone.
First use tweezers to peel away any remaining adhesive from both the back cover and the phone's chassis.
Then, clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
If it didn't already fall off, lift the metal camera plate away from the back cover. Carefully apply adhesive to the cover. Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. If that's not available, you can use a high-bond double-sided tape, such as Tesa 61395. With the new adhesive applied, reinstall the camera plate.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
Uma outra pessoa concluiu este guia.
2 comentários
Is the new adhesive applied to the back cover first, or to the phone first?
Hi Chris, the adhesive should be applied to the back cover first. Make sure you remove the camera plate first and apply the adhesive before reinstalling the plate. I’ve changed the guide to explain that better.
