Ir para o conteúdo principal
Motorola Moto X Lower Antenna Assembly Replacement
O que você precisa
  1. Motorola Moto X Lower Antenna Assembly Replacement, SIM Card: passo 1, imagem 1 %32 Motorola Moto X Lower Antenna Assembly Replacement, SIM Card: passo 1, imagem 2 %32 Motorola Moto X Lower Antenna Assembly Replacement, SIM Card: passo 1, imagem 3 %32
    • Insert the SIM card eject tool into the hole in the side of the SIM card tray and push to eject the tray.
    • Remove the SIM card tray.
    • If the SIM card does not fall free from the tray on its own, simply remove it with your fingers.
  2. Motorola Moto X Lower Antenna Assembly Replacement, Back Cover Assembly: passo 2, imagem 1 %32 Motorola Moto X Lower Antenna Assembly Replacement, Back Cover Assembly: passo 2, imagem 2 %32 Motorola Moto X Lower Antenna Assembly Replacement, Back Cover Assembly: passo 2, imagem 3 %32
    • In the following steps you will be releasing the clips holding the phone's cases together. However, the back case is also secured with an adhesive pad. After separating the clips you will use an iOpener to allow the case to fully open. Do not attempt to fully open the phone before loosening the adhesive.
    • Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot.
    • Slide the plastic opening tool along the seam toward the upper corner.
  3. Motorola Moto X Lower Antenna Assembly Replacement: passo 3, imagem 1 %32 Motorola Moto X Lower Antenna Assembly Replacement: passo 3, imagem 2 %32
    • Carefully slide the plastic opening tool around the corner, freeing it from clips.
  4. Motorola Moto X Lower Antenna Assembly Replacement: passo 4, imagem 1 %32 Motorola Moto X Lower Antenna Assembly Replacement: passo 4, imagem 2 %32
    • Pry around the top right corner of the phone between the two covers.
  5. Motorola Moto X Lower Antenna Assembly Replacement: passo 5, imagem 1 %32 Motorola Moto X Lower Antenna Assembly Replacement: passo 5, imagem 2 %32 Motorola Moto X Lower Antenna Assembly Replacement: passo 5, imagem 3 %32
    • Run the opening tool along the seam around all four sides, separating the remaining clips holding the cover on.
    • The plastic on the front cover is thinner near the buttons, and the buttons may move around. Go slowly to avoid damaging the buttons or the front cover.
    • Do not push the opening tool deep into phone, or you may damage internal components.
  6. Motorola Moto X Lower Antenna Assembly Replacement: passo 6, imagem 1 %32
    • Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
  7. Motorola Moto X Lower Antenna Assembly Replacement: passo 7, imagem 1 %32 Motorola Moto X Lower Antenna Assembly Replacement: passo 7, imagem 2 %32 Motorola Moto X Lower Antenna Assembly Replacement: passo 7, imagem 3 %32
    • Starting from the SIM slot side, carefully peel the back cover off of the phone.
    • The back cover is very flexible, but you don't want to damage any internal components by being too hasty.
    • There is a chance that the NFC coil may remain stubbornly adhered to the back cover. If that's the case, stop peeling the cover and reapply a heated iOpener to the back cover.
    • Do not separate the back cover entirely; it is still connected to the phone by the camera flash cable.
    • The flash cable is attached on the power/volume button side of the phone.
  8. Motorola Moto X Lower Antenna Assembly Replacement: passo 8, imagem 1 %32
    • Gently set the back cover down in a way that exposes the camera flash cable connector, but does not put strain on it.
  9. Motorola Moto X Lower Antenna Assembly Replacement: passo 9, imagem 1 %32 Motorola Moto X Lower Antenna Assembly Replacement: passo 9, imagem 2 %32 Motorola Moto X Lower Antenna Assembly Replacement: passo 9, imagem 3 %32
    • Use the tip of a spudger to flip up the retaining flap on the flash cable ZIF connector.
    • Be sure to pry only on the flap itself, not on the connector.
    • Pull the flash cable straight out of its socket.
  10. Motorola Moto X Lower Antenna Assembly Replacement: passo 10, imagem 1 %32
    • Separate the back cover from the phone.
  11. Motorola Moto X Lower Antenna Assembly Replacement, Lower Antenna Assembly: passo 11, imagem 1 %32
    • Remove the four 3 mm T3 Torx screws securing the lower antenna assembly to the phone.
  12. Motorola Moto X Lower Antenna Assembly Replacement: passo 12, imagem 1 %32 Motorola Moto X Lower Antenna Assembly Replacement: passo 12, imagem 2 %32 Motorola Moto X Lower Antenna Assembly Replacement: passo 12, imagem 3 %32
    • Use the flat end of a spudger to pry up the lower antenna assembly and free it from the phone.
    • Remove the antenna assembly.
Conclusão
9 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
467.161 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.895 guias
2 comentários
Where is the wifi antenna?
Fernando Coutinho - Responder
I considered repairing this after ripping the connector in the battery replacement procedure. I probably will not miss it, don't have the part either
David Karr - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 13
Duração total: 15,083
