Ir para o conteúdo principal
Motorola Moto X Headphone Jack/Speaker Assembly Replacement
O que você precisa
Vídeo de Apresentação
  1. Motorola Moto X Headphone Jack/Speaker Assembly Replacement, SIM Card: passo 1, imagem 1 %32 Motorola Moto X Headphone Jack/Speaker Assembly Replacement, SIM Card: passo 1, imagem 2 %32 Motorola Moto X Headphone Jack/Speaker Assembly Replacement, SIM Card: passo 1, imagem 3 %32
    • Insert the SIM card eject tool into the hole in the side of the SIM card tray and push to eject the tray.
    • Remove the SIM card tray.
    • If the SIM card does not fall free from the tray on its own, simply remove it with your fingers.
  2. Motorola Moto X Headphone Jack/Speaker Assembly Replacement, Back Cover Assembly: passo 2, imagem 1 %32 Motorola Moto X Headphone Jack/Speaker Assembly Replacement, Back Cover Assembly: passo 2, imagem 2 %32 Motorola Moto X Headphone Jack/Speaker Assembly Replacement, Back Cover Assembly: passo 2, imagem 3 %32
    • In the following steps you will be releasing the clips holding the phone's cases together. However, the back case is also secured with an adhesive pad. After separating the clips you will use an iOpener to allow the case to fully open. Do not attempt to fully open the phone before loosening the adhesive.
    • Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot.
    • Slide the plastic opening tool along the seam toward the upper corner.
  3. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 3, imagem 1 %32 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 3, imagem 2 %32
    • Carefully slide the plastic opening tool around the corner, freeing it from clips.
  4. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 4, imagem 1 %32 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 4, imagem 2 %32
    • Pry around the top right corner of the phone between the two covers.
  5. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 5, imagem 1 %32 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 5, imagem 2 %32 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 5, imagem 3 %32
    • Run the opening tool along the seam around all four sides, separating the remaining clips holding the cover on.
    • The plastic on the front cover is thinner near the buttons, and the buttons may move around. Go slowly to avoid damaging the buttons or the front cover.
    • Do not push the opening tool deep into phone, or you may damage internal components.
    Be *very* careful not to push the opening tool too deep when you go around the buttons! I accidentally broke the volume rocker ribbon by doing so, and didn't even realize it until I had completely removed the cover.
    Simeon Simeonides - Responder
    When i removed the volume rocker i cant get it back in correctly seems to be in right but the volume up is not clicking and only works if i push it really hard any ideas?
    Alf stevens - Responder
  6. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 6, imagem 1 %32
    • Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
    There is NO GLUE holding on the back of a Moto X with a wood back! That little fact just made the extra $50 I spent on the phone totally worthwhile.
    Doug Larrick - Responder
    Lucky for you, I have the bamboo, and plenty of adhesive.
    Kelly F -
  7. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 7, imagem 1 %32 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 7, imagem 2 %32 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 7, imagem 3 %32
    • Starting from the SIM slot side, carefully peel the back cover off of the phone.
    • The back cover is very flexible, but you don't want to damage any internal components by being too hasty.
    • There is a chance that the NFC coil may remain stubbornly adhered to the back cover. If that's the case, stop peeling the cover and reapply a heated iOpener to the back cover.
    • Do not separate the back cover entirely; it is still connected to the phone by the camera flash cable.
    • The flash cable is attached on the power/volume button side of the phone.
    Step 15 seemed to be the hardest part for me. (step 25, the battery was also difficult). I am now not a fan of sticky stuff, "Mild adhesive" is definitely an understatement, IMHO, just saying I don't like sticky stuff, maybe I didn't do it right. The iOpener seemed to help a little, but not much.
    CAUTION
    BE CAREFUL with the NFC antenna, it says "X8 Mobile Computing System" on it. The adhesive seemed stick to the the blue stuff on the back cover more and loosen up on the bottom of the antenna, the part that sticks to the battery. So in the process of peeling the back cover the antenna started to come up and was torn at the connector strip before I realized what was happening, step 19 has a good picture of the connector strip that I'm talking about. I like using NFC once in awhile, so now my next FIX will be the antenna.
    Overall instructions were GREAT, I now have a camera again. Thank you.
    Patrick - Responder
    So you are saying that there is no problem if I don't connect the NFC antenna? I'm asking this because I bought a replacement battery that don't include the NFC antenna. I would really appreciate your help with this :)
    jspsaucedo -
    The adhesive was crazy hard on mine as well and I ended up with two small cracks on the edges of my back cover. The blue rubber piece actually separated from the back and removed it from the battery after it was open. The battery itself was also very difficult to remove (pull tab did nothing) and bent/pried the old battery out. I see no reason for all that adhesive! Other than getting the dang thing open the rest was easy. Great guide!
    Darrell Jividen - Responder
    The adhesive holding the back very strong! In the process of removing the back, I cracked the edges of the back cover and ripped part of the NFC connector. Luckily the friend I was doing the repair for did not even know what NFC was, so she was ok with this. Take your time removing the back cover! Also, the adhesive holding the battery in place was not what I would call mild. The black tab was next to useless in removing the battery
    Danny Smandych - Responder
    jspsaucedo -
    Thank you for the guide !!! comments were really useful too. Read them.
    fabajaja - Responder
  8. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 8, imagem 1 %32
    • Gently set the back cover down in a way that exposes the camera flash cable connector, but does not put strain on it.
    As I had seen in another video, my Moto X with a custom back did not have the blue sticky pad. But the back was still well-adhered in the top corners and with a strip of adhesive along the bottom. In the photo in this step you can see the only adhesive I had to deal with, which was on either side of the lens (two dark areas on the phone back) and along the bottom of the phone (dark area at the bottom of the phone back).
    pdisc1 - Responder
  9. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 9, imagem 1 %32 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 9, imagem 2 %32 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 9, imagem 3 %32
    • Use the tip of a spudger to flip up the retaining flap on the flash cable ZIF connector.
    • Be sure to pry only on the flap itself, not on the connector.
    • Pull the flash cable straight out of its socket.
  10. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 10, imagem 1 %32
    • Separate the back cover from the phone.
  11. Motorola Moto X Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: passo 11, imagem 1 %32
    • Remove the five 3 mm T3 Torx screws from the headphone jack/speaker assembly.
  12. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 12, imagem 1 %32 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 12, imagem 2 %32 Motorola Moto X Headphone Jack/Speaker Assembly Replacement: passo 12, imagem 3 %32
    • Insert a spudger under the panhandle of the headphone jack/speaker assembly and pry it up from its recess.
    • Remove the headphone jack/speaker assembly.
Conclusão
4 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
465.602 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.718 guias
Um comentário
Is this the signal antenna?
I have one that says Searching for service and no matter what it won’t detect any network.
Not sure if this or the lower antenna are responsible for cellular signal.
Rafael B - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 5,816
