Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Suffering from a rapidly waning, or non-existent, battery life? Use this guide to replace the battery in your Motorola Moto X. If your battery is swollen, take appropriate precautions.
O que você precisa
Vídeo de Apresentação
Insert the SIM card eject tool into the hole in the side of the SIM card tray and push to eject the tray.
Remove the SIM card tray.
Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot.
Slide the plastic opening tool along the seam toward the upper corner.
Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
Remove the four 3 mm T3 Torx screws securing the lower antenna assembly to the phone.
Insert the tip of a spudger under the battery cable near the connector to lift it straight up from its socket.
Use the flat end of a spudger to disconnect the NFC antenna cable connector.
If you choose not to, or if you damage the coil, your phone will work without it, but lose its NFC capabilities.
Apply a heated iOpener to the NFC antenna for 90 seconds.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
After completing this guide, calibrate your newly-installed battery.
Repair didn’t go as planned? Check out our Motorola Moto X Answers community for troubleshooting help.
114 outras pessoas executaram este guia.
35 comentários
Cool but where to buy the spare battery?
Thanks
Nice, detailed guide. In fact so detailed, I do not trust myself making this repair. Does anyone offer this as a service (for a fee)?
This doesn't address the antenna stuck on (but separate) from the battery. It's easy enough to see in the pictures, but it doesn't come off easily in one piece. I think mine still works, but definitely needs addressing.
Yes - getting the antenna off is a bear. I - well, my cell-phone guy - didn't bother because I don't use NFC for anything, so I hope that was okay!
