Ir para o conteúdo principal
Motorola Moto X 2nd Generation Battery Replacement
O que você precisa
  1. Motorola Moto X 2nd Generation Battery Replacement, Battery: passo 1, imagem 1 %32 Motorola Moto X 2nd Generation Battery Replacement, Battery: passo 1, imagem 2 %32 Motorola Moto X 2nd Generation Battery Replacement, Battery: passo 1, imagem 3 %32
    • Remove the SIM card tray by inserting the SIM card eject tool into the small hole on the tray.
  2. Motorola Moto X 2nd Generation Battery Replacement: passo 2, imagem 1 %32 Motorola Moto X 2nd Generation Battery Replacement: passo 2, imagem 2 %32 Motorola Moto X 2nd Generation Battery Replacement: passo 2, imagem 3 %32
    • Insert a SIM eject tool into the SIM tray slot, and through a small hole in the mid frame.
    • Push the SIM eject tool through the hole and against the back cover to lift the cover slightly.
    • Insert an opening pick into the gap created with the SIM eject tool, and slide the pick around the edge of the cover to cut the cover's adhesive.
    • Cut carefully near the volume buttons, to avoid damaging the delicate ribbon cables in that area under the cover.
    • Remove back cover.
  3. Motorola Moto X 2nd Generation Battery Replacement: passo 3, imagem 1 %32 Motorola Moto X 2nd Generation Battery Replacement: passo 3, imagem 2 %32
    • Remove the rubber covers from the two connector pieces indicated in the photo
  4. Motorola Moto X 2nd Generation Battery Replacement: passo 4, imagem 1 %32 Motorola Moto X 2nd Generation Battery Replacement: passo 4, imagem 2 %32
    • Use the spudger to release the connectors from under the covers.
  5. Motorola Moto X 2nd Generation Battery Replacement: passo 5, imagem 1 %32 Motorola Moto X 2nd Generation Battery Replacement: passo 5, imagem 2 %32
    • Use a T3 Torx driver to remove the screws.
    • Remove the middle housing from front assembly.
  6. Motorola Moto X 2nd Generation Battery Replacement: passo 6, imagem 1 %32 Motorola Moto X 2nd Generation Battery Replacement: passo 6, imagem 2 %32 Motorola Moto X 2nd Generation Battery Replacement: passo 6, imagem 3 %32
    • Remove the logo, as the flex cable under the logo is fastened to the back of the battery. This can be done by removing the three surrounding screws, and then prying off the structure that encapsulates the logo.
  7. Motorola Moto X 2nd Generation Battery Replacement: passo 7, imagem 1 %32 Motorola Moto X 2nd Generation Battery Replacement: passo 7, imagem 2 %32
    • Use the flat end of a spudger to gently pry up the ribbon cable in the two places where it is adhered to the battery.
  8. Motorola Moto X 2nd Generation Battery Replacement: passo 8, imagem 1 %32 Motorola Moto X 2nd Generation Battery Replacement: passo 8, imagem 2 %32 Motorola Moto X 2nd Generation Battery Replacement: passo 8, imagem 3 %32
    • Lift one of the two battery adhesive tabs and pull firmly and steadily toward the bottom edge of the phone, until the adhesive strip slides all the way out from between the battery and the phone.
    • Repeat for the other adhesive tab.
    • Remove the battery.
    • If the adhesive strips do not fully come out you will need to pry it out from the other side, but be VERY careful as the NFC coil is under the battery and can be ripped easily.
Conclusão
After completing this guide, calibrate your newly-installed battery.
52 outras pessoas executaram este guia.
Sophia
Membro desde: 03/25/14
43.810 Reputação
Autoria de 62 guias
37 comentários
Are you friggin' kidding me. Why would Motorola make a major project out of simply removing a battery. Definately needs to be simplified. It'seems like doing friggin' surgery on a phone.
tspeanut122 - Responder
Too funny! hahahha
Pamela Orjuela -
I'd call this battery replacement requirement 'built in obsolescence'! There's no way I'd attempt this. I'd rather buy a new phone. Then again, that's probably why it's so complicated...
Ben Miller - Responder
LOL Obviously you've never replaced a laptop motherboard ;)
nightopz - Responder
How do you repeat the steps in reverse such that you replace the adhesive holding the battery in place? Does a new battery come with the adhesive?
Richard Glendinning - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 48
Duração total: 78,276
