Ir para o conteúdo principal
Motorola Moto Q Keyboard Replacement
O que você precisa
  1. Motorola Moto Q Keyboard Replacement, Back Casing: passo 1, imagem 1 %32
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Motorola Moto Q Keyboard Replacement: passo 2, imagem 1 %32
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Motorola Moto Q Keyboard Replacement: passo 3, imagem 1 %32 Motorola Moto Q Keyboard Replacement: passo 3, imagem 2 %32
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Motorola Moto Q Keyboard Replacement: passo 4, imagem 1 %32 Motorola Moto Q Keyboard Replacement: passo 4, imagem 2 %32
    • Gently lift and remove the back casing.
  5. Motorola Moto Q Keyboard Replacement, Camera: passo 5, imagem 1 %32 Motorola Moto Q Keyboard Replacement, Camera: passo 5, imagem 2 %32
    • Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
    • Gently rotate/wiggle the cover until you can pull it off the phone.
  6. Motorola Moto Q Keyboard Replacement: passo 6, imagem 1 %32 Motorola Moto Q Keyboard Replacement: passo 6, imagem 2 %32
    • Using your fingers, remove the plastic piece that holds the camera in place.
  7. Motorola Moto Q Keyboard Replacement: passo 7, imagem 1 %32 Motorola Moto Q Keyboard Replacement: passo 7, imagem 2 %32
    • Carefully pry up the upper circuit board with the spudger.
    • The second picture shows what your phone should look like when the upper circuit board is removed.
  8. Motorola Moto Q Keyboard Replacement: passo 8, imagem 1 %32 Motorola Moto Q Keyboard Replacement: passo 8, imagem 2 %32
    • Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
  9. Motorola Moto Q Keyboard Replacement, Keyboard: passo 9, imagem 1 %32 Motorola Moto Q Keyboard Replacement, Keyboard: passo 9, imagem 2 %32 Motorola Moto Q Keyboard Replacement, Keyboard: passo 9, imagem 3 %32
    • The keyboard is held in place with a little bit of glue.
    • Simply lift the keyboard buttons with your hands pulling from one side to the other.
Conclusão
Luis Herrera
Membro desde: 01/21/10
52 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 16-33, Maness Winter 2010 Membro de Cal Poly, Team 16-33, Maness Winter 2010
CPSU-MANESS-W10S16G33
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 4,097
