Ir para o conteúdo principal
Motorola Moto Q Back Casing Replacement
O que você precisa
  1. Motorola Moto Q Back Casing Replacement, Back Casing: passo 1, imagem 1 %32
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Motorola Moto Q Back Casing Replacement: passo 2, imagem 1 %32
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Motorola Moto Q Back Casing Replacement: passo 3, imagem 1 %32 Motorola Moto Q Back Casing Replacement: passo 3, imagem 2 %32
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Motorola Moto Q Back Casing Replacement: passo 4, imagem 1 %32 Motorola Moto Q Back Casing Replacement: passo 4, imagem 2 %32
    • Gently lift and remove the back casing.
Conclusão
Luis Herrera
Membro desde: 01/21/10
52 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 16-33, Maness Winter 2010 Membro de Cal Poly, Team 16-33, Maness Winter 2010
CPSU-MANESS-W10S16G33
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 5,142
