Ir para o conteúdo principal
Motorola Moto G7 Screen Replacement
O que você precisa
  1. Motorola Moto G7 Screen Replacement, Screen: passo 1, imagem 1 %32 Motorola Moto G7 Screen Replacement, Screen: passo 1, imagem 2 %32 Motorola Moto G7 Screen Replacement, Screen: passo 1, imagem 3 %32
    • Use the iFixit opening tools to gently wedge the front screen from the rest of the device.
    • Try to focus on the corners to make it easier to insert and use the iFixit opening picks.
    • It is also recommended to use the iOpener or a heat gun to weaken the adhesive that holds the edges of the screen down.
    • The screen is glass, so when using force to lift the screen, be cautious of cracked glass and stray shards of glass coming off.
    • You have to be extra careful to dig deep enough, so you lift the entire screen unit!
  2. Motorola Moto G7 Screen Replacement: passo 2, imagem 1 %32
    • Excessive glass and adhesive around the edges should be removed with the spudger.
    • The glass is black and may blend in with edges of the device. Be cautious using bare hands when moving the device.
  3. Motorola Moto G7 Screen Replacement: passo 3, imagem 1 %32 Motorola Moto G7 Screen Replacement: passo 3, imagem 2 %32
    • Remove three 2.7mm T3 Torx screws from the metal piece to the right of the battery.
  4. Motorola Moto G7 Screen Replacement: passo 4, imagem 1 %32 Motorola Moto G7 Screen Replacement: passo 4, imagem 2 %32 Motorola Moto G7 Screen Replacement: passo 4, imagem 3 %32
    • Use a spudger to gently take off the metal piece that was held down by the screws.
    • A second metal piece is held under the first. This can also be popped off by using the spudger and nudging it under the metal piece connected to the band.
Conclusão
16 outras pessoas executaram este guia.
Peter Nelson
Membro desde: 01/23/20
742 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S19-G6, White Winter 2020 Membro de Cal Poly, Team S19-G6, White Winter 2020
CPSU-WHITE-W20S19G6
Membros da 4
Autoria de 20 guias
3 comentários
The replacement part listed here on iFixit indicates installation adhesive is not included. Can you reuse the adhesive on the old part? If not, what adhesive is recommended for this type of repair?
Gabe LaBounty - Responder
You can’t. I used the 1 mil tape and it worked.
Javier Vilalta - Responder
How much would it cost to send this in for someone else to put in a new screen?
Nathaniel Mcvay - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 20
Últimos 30 dias: 100
Duração total: 11,904
