Introdução
In this guide, we will show you how to remove the front camera for this device. We recommend that you have a tray or a magnetic pad to place the several small t5 screws which will be removed because they are easy to lose. Next, it is recommended that you have an iFixIt tool kit or at least a spudger, a Torx T5 screwdriver, and a pick to help with removing the components of this device.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
O que você precisa
Insert an opening tool pick under the screen, starting at the top of the phone.
Slide the pick around the entire perimeter of the display to break the adhesive.
Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
Gently remove the metal piece that covers the base of the display cable.
Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
