Ir para o conteúdo principal
Motorola Moto G7 Plus Rear Camera Replacement
O que você precisa
  1. Motorola Moto G7 Plus  Rear Camera Replacement, Remove the Screen: passo 1, imagem 1 %32 Motorola Moto G7 Plus  Rear Camera Replacement, Remove the Screen: passo 1, imagem 2 %32
    • Insert an opening tool pick under the screen, starting at the top of the phone.
    • Slide the pick around the entire perimeter of the display to break the adhesive.
    • There is a cable on the right side of the phone (the side with the volume buttons), which connects the screen to the rest of the phone. Be careful not to damage this cable.
    • Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
    • While not necessary, applying a gentle heat to the edges of the display with a heat gun or iOpener will weaken the adhesive.
  2. Motorola Moto G7 Plus  Rear Camera Replacement, Remove the Display Cable Cover: passo 2, imagem 1 %32 Motorola Moto G7 Plus  Rear Camera Replacement, Remove the Display Cable Cover: passo 2, imagem 2 %32
    • Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
    • Gently remove the metal piece that covers the base of the display cable.
  3. Motorola Moto G7 Plus  Rear Camera Replacement: passo 3, imagem 1 %32 Motorola Moto G7 Plus  Rear Camera Replacement: passo 3, imagem 2 %32
    • Use the pointed end of the spudger to lift the metal casing where circled.
  4. Motorola Moto G7 Plus  Rear Camera Replacement, Separate the Display From the Phone: passo 4, imagem 1 %32 Motorola Moto G7 Plus  Rear Camera Replacement, Separate the Display From the Phone: passo 4, imagem 2 %32
    • Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
  5. Motorola Moto G7 Plus  Rear Camera Replacement, Speaker: passo 5, imagem 1 %32 Motorola Moto G7 Plus  Rear Camera Replacement, Speaker: passo 5, imagem 2 %32
    • Use the Torx T5 screwdriver to remove the three 3.0 mm screws.
  6. Motorola Moto G7 Plus  Rear Camera Replacement: passo 6, imagem 1 %32 Motorola Moto G7 Plus  Rear Camera Replacement: passo 6, imagem 2 %32 Motorola Moto G7 Plus  Rear Camera Replacement: passo 6, imagem 3 %32
    • Use the spudger to lift up the right side of the speaker and remove the speaker from the device.
    • A medium amount of force may be required.
  7. Motorola Moto G7 Plus  Rear Camera Replacement, Rear Camera: passo 7, imagem 1 %32 Motorola Moto G7 Plus  Rear Camera Replacement, Rear Camera: passo 7, imagem 2 %32 Motorola Moto G7 Plus  Rear Camera Replacement, Rear Camera: passo 7, imagem 3 %32
    • Use the spudger to carefully slice through the black adhesive.
    • Use a Torx T5 screwdriver to remove the four 2.7mm screws.
  8. Motorola Moto G7 Plus  Rear Camera Replacement: passo 8, imagem 1 %32 Motorola Moto G7 Plus  Rear Camera Replacement: passo 8, imagem 2 %32 Motorola Moto G7 Plus  Rear Camera Replacement: passo 8, imagem 3 %32
    • Use the SIM card ejector tool to remove the SIM card tray where circled.
    • Completely remove the SIM card tray from the phone as shown in the picture.
  9. Motorola Moto G7 Plus  Rear Camera Replacement: passo 9, imagem 1 %32 Motorola Moto G7 Plus  Rear Camera Replacement: passo 9, imagem 2 %32 Motorola Moto G7 Plus  Rear Camera Replacement: passo 9, imagem 3 %32
    • Use a Torx T5 screwdriver to remove the six 2.7mm screws and one 3.0mm screw.
    • Remove the plate from the phone.
  10. Motorola Moto G7 Plus  Rear Camera Replacement: passo 10, imagem 1 %32
    • Use a spudger to disconnect the bands.
  11. Motorola Moto G7 Plus  Rear Camera Replacement: passo 11, imagem 1 %32 Motorola Moto G7 Plus  Rear Camera Replacement: passo 11, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently lift up the piece either with your fingers or a spudger.
    • Use the reverse tweezers to gently remove the piece from underneath.
Conclusão
Kritika Sigdel
Membro desde: 02/10/20
171 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S22-G5, Regan Winter 2020 Membro de Cal Poly, Team S22-G5, Regan Winter 2020
CPSU-REGAN-W20S22G5
Membros da 5
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 1,667
