Ir para o conteúdo principal
Motorola Moto G5 Vibration Motor Replacement
O que você precisa
  1. Motorola Moto G5 Vibration Motor Replacement, Back Cover: passo 1, imagem 1 %32 Motorola Moto G5 Vibration Motor Replacement, Back Cover: passo 1, imagem 2 %32
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Vibration Motor Replacement: passo 2, imagem 1 %32 Motorola Moto G5 Vibration Motor Replacement: passo 2, imagem 2 %32 Motorola Moto G5 Vibration Motor Replacement: passo 2, imagem 3 %32
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Vibration Motor Replacement: passo 3, imagem 1 %32 Motorola Moto G5 Vibration Motor Replacement: passo 3, imagem 2 %32 Motorola Moto G5 Vibration Motor Replacement: passo 3, imagem 3 %32
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Vibration Motor Replacement: passo 4, imagem 1 %32 Motorola Moto G5 Vibration Motor Replacement: passo 4, imagem 2 %32
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Vibration Motor Replacement, Battery: passo 5, imagem 1 %32 Motorola Moto G5 Vibration Motor Replacement, Battery: passo 5, imagem 2 %32
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Vibration Motor Replacement: passo 6, imagem 1 %32
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Vibration Motor Replacement, Vibration Motor: passo 7, imagem 1 %32
    • Remove the nine (9) 4mm Philips screws securing the daughterboard cover.
  8. Motorola Moto G5 Vibration Motor Replacement: passo 8, imagem 1 %32
    • Remove the plastic casing on the bottom of the phone by gently pulling.
  9. Motorola Moto G5 Vibration Motor Replacement: passo 9, imagem 1 %32 Motorola Moto G5 Vibration Motor Replacement: passo 9, imagem 2 %32 Motorola Moto G5 Vibration Motor Replacement: passo 9, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the three connectors on the board below the battery slow by gently pulling on the small gold tab with a pair of tweezers.
  10. Motorola Moto G5 Vibration Motor Replacement: passo 10, imagem 1 %32
    • Remove the 3.4 mm Philips screw securing the daughterboard to the frame.
  11. Motorola Moto G5 Vibration Motor Replacement: passo 11, imagem 1 %32
    • Use the point of a spudger to lift the vibration motor connector up out of the socket on the I/O board.
    • Be very careful to pry only on the connector under the red and black cables, not on the socket itself.
Conclusão
7 outras pessoas executaram este guia.
Miles Cobb
Membro desde: 01/24/18
371 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S2-G3, Livingston Winter 2018 Membro de Cal Poly, Team S2-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G3
Membros da 4
Autoria de 16 guias
Um comentário
Is this also where the mic is located?
Matt - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 29
Duração total: 3,452
