Ir para o conteúdo principal
Motorola Moto G5 Motherboard Replacement
O que você precisa
  1. Motorola Moto G5 Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Motorola Moto G5 Motherboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Motherboard Replacement: passo 2, imagem 1 %32 Motorola Moto G5 Motherboard Replacement: passo 2, imagem 2 %32 Motorola Moto G5 Motherboard Replacement: passo 2, imagem 3 %32
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Motherboard Replacement: passo 3, imagem 1 %32 Motorola Moto G5 Motherboard Replacement: passo 3, imagem 2 %32 Motorola Moto G5 Motherboard Replacement: passo 3, imagem 3 %32
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Motherboard Replacement: passo 4, imagem 1 %32 Motorola Moto G5 Motherboard Replacement: passo 4, imagem 2 %32
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Motherboard Replacement, Battery: passo 5, imagem 1 %32 Motorola Moto G5 Motherboard Replacement, Battery: passo 5, imagem 2 %32
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Motherboard Replacement, Rear Facing Camera: passo 7, imagem 1 %32 Motorola Moto G5 Motherboard Replacement, Rear Facing Camera: passo 7, imagem 2 %32
    • Remove the eight (8) 4mm screws with a Phillips screwdriver.
  8. Motorola Moto G5 Motherboard Replacement: passo 8, imagem 1 %32 Motorola Moto G5 Motherboard Replacement: passo 8, imagem 2 %32 Motorola Moto G5 Motherboard Replacement: passo 8, imagem 3 %32
    • Pry the top motherboard cover off using a plastic opening tool.
    • When prying it open, make sure to pry it around evenly so that the cover will not snap. This will require some force.
  9. Motorola Moto G5 Motherboard Replacement: passo 9, imagem 1 %32 Motorola Moto G5 Motherboard Replacement: passo 9, imagem 2 %32 Motorola Moto G5 Motherboard Replacement: passo 9, imagem 3 %32
    • Disconnect the marked connector with a pair of tweezers and remove the camera piece.
  10. Motorola Moto G5 Motherboard Replacement, Motherboard: passo 10, imagem 1 %32
    • Remove the two 4mm screws shown in the picture using a Phillips #00 screwdriver.
  11. Motorola Moto G5 Motherboard Replacement: passo 11, imagem 1 %32
    • Lift the motherboard up from the top of the phone.
  12. Motorola Moto G5 Motherboard Replacement: passo 12, imagem 1 %32
    • Unplug the back connector from the motherboard using tweezers.
Conclusão
10 outras pessoas executaram este guia.
Luis Garcia
Membro desde: 01/24/18
289 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S2-G3, Livingston Winter 2018 Membro de Cal Poly, Team S2-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G3
Membros da 4
Autoria de 16 guias
2 comentários
is a xt1670 logic board compatible with a xt1671 phone?
Jaime Oziel Moreno - Responder
While disassembling I accidentally broke off one of the antenna "pins" (the one under the audio jack). I'll try to solder it on again, but in case I cannot, you think it will affect its proper operation too much? I cannot test it right now as I am waiting a replacement side buttons board.
karajay - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 29
Duração total: 6,183
