Introdução
This guide will walk you through the process of replacing the rear camera in a Motorola Moto G4 Plus phone.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
O que você precisa
Insert a fingernail or a spudger into the notch on bottom edge of the phone near the charging port.
Pry the back cover away from the body of the phone.
Using tweezers, lift up the black silicon piece connecting the motherboard to the front casing.
Using tweezers, remove the red and black cable connecting the motherboard to the front casing.
Using tweezers, remove the yellow film connecting the motherboard to the rear camera.
