Introdução
Use this guide to replace the midframe of your Motorola Moto G4 Play if damaged, or to access the internal components. Consider using a magnetic mat to organize the screws that will be removed from the device.
O que você precisa
Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
