Introdução
Use this guide to:
- Replace or remove the battery
- As a starting point for any other repair/replacement needed on the phone, since it's hazardous to keep the battery in
If your battery is swollen, take appropriate precautions.
O que você precisa
Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
6 outras pessoas executaram este guia.
