Introdução
If you have a cracked or damaged lens then it's best to replace it so your photos are crystal clear again. Follow this guide to do it yourself!
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
O que você precisa
Place your thumb in the indent located at bottom left corner of the back cover.
The cover will pop up and begin to lift
Continue to slide your fingers up the sides to remove the back cover
6 outras pessoas executaram este guia.
