Ir para o conteúdo principal
Motorola Moto G Stylus 4G (2023) Screen Replacement
O que você precisa
    1. Motorola Moto G Stylus 4G (2023) Screen Replacement, Battery: passo 1, imagem 1 %32 Motorola Moto G Stylus 4G (2023) Screen Replacement, Battery: passo 1, imagem 2 %32
      • Insert an opening pick under the edge of the case and slide it around the edges.
      • Separate the back panel from the rest of the phone.
      Pergunte ao FixBot
      Comentar
    2. Motorola Moto G Stylus 4G (2023) Screen Replacement: passo 2, imagem 1 %32
      • Remove the seven 4 mm screws from the phone’s top with a Torx T5 screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Motorola Moto G Stylus 4G (2023) Screen Replacement: passo 3, imagem 1 %32 Motorola Moto G Stylus 4G (2023) Screen Replacement: passo 3, imagem 2 %32
      • Use the opening pick along the edges to separate the camera lens glass from the board. If you begin to pry where the picture indicates, you will only get the top plastic and it will peal away from the paint. Instead begin at the gap in the lower left hand corner where there is a space between the actual frame that contains the lenses and the phone.
      Pergunte ao FixBot
      Comentar
    4. Motorola Moto G Stylus 4G (2023) Screen Replacement: passo 4, imagem 1 %32
      • Remove three 4 mm screws with a Torx T5 screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Motorola Moto G Stylus 4G (2023) Screen Replacement: passo 5, imagem 1 %32
      • Pry off the top perimeter with an ESD-safe spudger and set it aside.
      Pergunte ao FixBot
      Comentar
    6. Motorola Moto G Stylus 4G (2023) Screen Replacement: passo 6, imagem 1 %32 Motorola Moto G Stylus 4G (2023) Screen Replacement: passo 6, imagem 2 %32
      • Pull the black tab off of the battery gently with your hand.
      Pergunte ao FixBot
      Comentar
    7. Motorola Moto G Stylus 4G (2023) Screen Replacement: passo 7, imagem 1 %32 Motorola Moto G Stylus 4G (2023) Screen Replacement: passo 7, imagem 2 %32
      • Disconnect the four cables by inserting the opening pick beneath the edge of each.
      Pergunte ao FixBot
      Comentar
    8. Motorola Moto G Stylus 4G (2023) Screen Replacement: passo 8, imagem 1 %32 Motorola Moto G Stylus 4G (2023) Screen Replacement: passo 8, imagem 2 %32
      • Together with the opening pick and an ESD-safe spudger, remove the old battery.
      Pergunte ao FixBot
      Comentar
    1. Motorola Moto G Stylus 4G (2023) Screen Replacement, Screen: passo 9, imagem 1 %32
      • Apply heat using a heat gun to soften the adhesive around the edges of the screen.
      • Avoid overheating to prevent damage to the device.
      Pergunte ao FixBot
      Comentar
    2. Motorola Moto G Stylus 4G (2023) Screen Replacement: passo 10, imagem 1 %32 Motorola Moto G Stylus 4G (2023) Screen Replacement: passo 10, imagem 2 %32
      • Insert a Jimmy into the crevice between the screen and the rest of the phone.
      • Work around the edges to gently pry the screen away from the phone.
      • Be careful to avoid glass fragments from the broken screen.
      Pergunte ao FixBot
      Comentar
    3. Motorola Moto G Stylus 4G (2023) Screen Replacement: passo 11, imagem 1 %32
      • Use a spudger to disconnect the screen connectors from the motherboard.
      • Remove any screws that are holding the screen in place.
      Pergunte ao FixBot
      Comentar
    4. Motorola Moto G Stylus 4G (2023) Screen Replacement: passo 12, imagem 1 %32
      • Remove the screen from the phone.
      • Clean the frame of any adhesive residue or glass shards.
      • Align the new screen to check its fit to the frame. Place the new screen with new adhesive.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 43
Últimos 30 dias: 146
Ao todo: 3,292
