Ir para o conteúdo principal
Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement
O que você precisa
  1. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement, Battery: passo 1, imagem 1 %32 Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Insert an opening pick under the edge of the case and slide it around the edges.
    • Separate the back panel from the rest of the phone.
    Pergunte ao FixBot
    Comentar
  2. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: passo 2, imagem 1 %32
    • Remove the seven 4 mm screws from the phone’s top with a Torx T5 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: passo 3, imagem 1 %32 Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: passo 3, imagem 2 %32
    • Use the opening pick along the edges to separate the camera lens glass from the board. If you begin to pry where the picture indicates, you will only get the top plastic and it will peal away from the paint. Instead begin at the gap in the lower left hand corner where there is a space between the actual frame that contains the lenses and the phone.
    Pergunte ao FixBot
    Comentar
  4. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: passo 4, imagem 1 %32
    • Remove three 4 mm screws with a Torx T5 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: passo 5, imagem 1 %32
    • Pry off the top perimeter with an ESD-safe spudger and set it aside.
    Pergunte ao FixBot
    Comentar
  6. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: passo 6, imagem 1 %32 Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: passo 6, imagem 2 %32
    • Pull the black tab off of the battery gently with your hand.
    Pergunte ao FixBot
    Comentar
  7. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: passo 7, imagem 1 %32 Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: passo 7, imagem 2 %32
    • Disconnect the four cables by inserting the opening pick beneath the edge of each.
    Pergunte ao FixBot
    Comentar
  8. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: passo 8, imagem 1 %32 Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: passo 8, imagem 2 %32
    • Together with the opening pick and an ESD-safe spudger, remove the old battery.
    Pergunte ao FixBot
    Comentar
  9. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement, Ringer Speaker: passo 9, imagem 1 %32
    • Remove seven 4 mm screws with the T5 Torx screwdriver.
    Pergunte ao FixBot
    Comentar
  10. Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: passo 10, imagem 1 %32 Motorola Moto G Stylus 4G (2023) Ringer Speaker Replacement: passo 10, imagem 2 %32
    • Remove the speaker using an ESD-safe spudger.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 35
Ao todo: 381
