Ir para o conteúdo principal
Motorola Moto G Power (2020) Fingerprint Sensor Replacement
  1. Motorola Moto G Power (2020) Fingerprint Sensor Replacement, Back Panel: passo 1, imagem 1 %32
    • Place a suction cup on the back of the device.
    • Then open up the back of the device by sliding the opening pick into both sides of the phone.
    • Do not remove the back panel completely; you must disconnect the fingerprint sensor first.
  2. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: passo 2, imagem 1 %32
    • Put pressure on the fingerprint sensor with your finger to detach it from the back panel.
    • You may have to use significant force to get the circular sensor off the panel.
  3. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: passo 3, imagem 1 %32
    • Completely remove the back panel from the device.
  4. Motorola Moto G Power (2020) Fingerprint Sensor Replacement, Fingerprint Sensor: passo 4, imagem 1 %32
    • Using a Torx T3 screwdriver, remove nine 2.2 mm screws.
  5. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: passo 5, imagem 1 %32 Motorola Moto G Power (2020) Fingerprint Sensor Replacement: passo 5, imagem 2 %32 Motorola Moto G Power (2020) Fingerprint Sensor Replacement: passo 5, imagem 3 %32
    • Use the spudger to gently lift the cover.
    • If needed, use the spudger's tip against a corner of the cover to help lift it.
    • Set the back cover aside.
    • DO NOT use excessive force when lifting up the back cover.
  6. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: passo 6, imagem 1 %32
    • Carefully use the spudger to lift the sensor cable, disconnecting the fingerprint sensor from the motherboard.
    • WARNING: Handle the sensor cable with care; it can be easily damaged.
  7. Motorola Moto G Power (2020) Fingerprint Sensor Replacement: passo 7, imagem 1 %32
    • Carefully remove the fingerprint sensor from the device and set it aside.
    • Do not use excessive force when lifting the back cover or any other component.
Conclusão
Harry Jung
Membro desde: 06/23/22
736 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 25
Duração total: 648
