Ir para o conteúdo principal
Motorola Moto G 2nd Generation Speakers Replacement
O que você precisa
  1. Motorola Moto G 2nd Generation Speakers Replacement, Battery: passo 1, imagem 1 %32 Motorola Moto G 2nd Generation Speakers Replacement, Battery: passo 1, imagem 2 %32 Motorola Moto G 2nd Generation Speakers Replacement, Battery: passo 1, imagem 3 %32
    • Make sure your Moto G is turned off and that any SIM or SD cards are removed before beginning disassembly.
    • Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger.
    • Work your way down the sides to avoid cracking the rear cover.
    Important - remove SIM cards before opening the phone.
    Wojciech Dyba - Responder
  2. Motorola Moto G 2nd Generation Speakers Replacement: passo 2, imagem 1 %32 Motorola Moto G 2nd Generation Speakers Replacement: passo 2, imagem 2 %32 Motorola Moto G 2nd Generation Speakers Replacement: passo 2, imagem 3 %32
    • Remove the eight 4.2 mm screws at the top and bottom of the phone using a T5 Torx screwdriver.
    • Using the same screwdriver, remove the six 3.2 mm screws on the sides.
    • Remove the next layer of the phone by prying it off with your fingers.
    On mine, they’re all Torx T5
    Stanley Reynolds - Responder
    You neglected to mention that the two buttons might fall out when you remove this part.
  3. Motorola Moto G 2nd Generation Speakers Replacement: passo 3, imagem 1 %32 Motorola Moto G 2nd Generation Speakers Replacement: passo 3, imagem 2 %32 Motorola Moto G 2nd Generation Speakers Replacement: passo 3, imagem 3 %32
    • Using a plastic opening tool or tweezers, disconnect the SIM/SD card reader at the top of the phone.
    • Disconnect the battery connector by prying it off of the motherboard.
    • Disconnect the vibration motor by prying its connector off of the motherboard.
    sir when I put on for charging it shows 50% charging after 1 hour when I removed the charger its showin 0 and total is dead. what is the reason
    leela - Responder
    moto g 2 completely dead what the reason
    leela - Responder
    There's no need to remove the battery or motherboard to get to the speakers - they are accessible as soon as the back cover is removed. Skip this step and jump straight to step 10
    Paul Abraham - Responder
    In fact it is not necessary to remove the simcard rack. I managed to remove battery with the rack on. It is possible to remove the foil startingfrom the bottom of the battery and once peeled off the battery can be removed. You only need to disconnect the battery from the mother board.
  4. Motorola Moto G 2nd Generation Speakers Replacement: passo 4, imagem 1 %32 Motorola Moto G 2nd Generation Speakers Replacement: passo 4, imagem 2 %32 Motorola Moto G 2nd Generation Speakers Replacement: passo 4, imagem 3 %32
    • Using a plastic opening tool, carefully pry off the entire SIM/SD card reader component.
    • Don't worry about ripping the copper foil a little bit, it is easy to put back on.
    • When reassembling the device, do not attempt to smooth the foil down with your finger. Metal foil can become sharp if folded in a certain way, and you may be cut.
    • The battery may be removed without removing the SIM/SD card reader. Simply peel back the copper foil from the opposite end of the device, stopping just before you reach the SIM/SD card reader.
    As mentioned in a comment on the previous step, you don’t actually need to remove the SIM/SD card reader at all.
    If you peel back the copper foil from the opposite end of the device, you can sneak the battery out (and the new battery in) by just sliding the battery ribbon cable out from under the SIM/SD card reader.
    David - Responder
    Thx for the idea. I’ll let you know if it was working - I’ll my battery soon. regards!
    ausssiefan - Responder
    Perfect as mentioned - just slide the cable foil under the sim rack - no need to remove the rack. Works flawlessly, quick repair.
    ausssiefan -
  5. Motorola Moto G 2nd Generation Speakers Replacement: passo 5, imagem 1 %32 Motorola Moto G 2nd Generation Speakers Replacement: passo 5, imagem 2 %32 Motorola Moto G 2nd Generation Speakers Replacement: passo 5, imagem 3 %32
    • Peel off the two black stickers on the right side of the battery using your fingers.
    • Remove the battery by pulling the right side of it upwards.
    • The black stickers are the protruding ends of the two parallel adhesive strips which hold the battery in place. You can see the adhesive strips in the third image. Focus your effort on these regions.
    • If you did not remove the SIM/SD card reader in the previous step, you will need to carefully slide the battery ribbon cable out from under it once you have freed the battery from the adhesive strips.
    HINT: The ‘two black stickers’ are the ends of the two parallel adhesive strips which hold the battery in. There is no other adhesive holding the battery, so focus your attention on these regions when prying the battery out!
    David - Responder
    If the copper foil is damaged beyond repair, what can be used to replace it?
    Xander Squier - Responder
  6. Motorola Moto G 2nd Generation Speakers Replacement, Motherboard: passo 6, imagem 1 %32 Motorola Moto G 2nd Generation Speakers Replacement, Motherboard: passo 6, imagem 2 %32 Motorola Moto G 2nd Generation Speakers Replacement, Motherboard: passo 6, imagem 3 %32
    • Remove LCD connector by lifting the black plastic flap.
  7. Motorola Moto G 2nd Generation Speakers Replacement: passo 7, imagem 1 %32 Motorola Moto G 2nd Generation Speakers Replacement: passo 7, imagem 2 %32 Motorola Moto G 2nd Generation Speakers Replacement: passo 7, imagem 3 %32
    • Using a T5 Torx screwdriver, unscrew the three 2.2 mm screws holding the motherboard in place.
  8. Motorola Moto G 2nd Generation Speakers Replacement: passo 8, imagem 1 %32 Motorola Moto G 2nd Generation Speakers Replacement: passo 8, imagem 2 %32
    • Carefully remove the motherboard.
    from here ill get motherboard for g2
    prem surve - Responder
  9. Motorola Moto G 2nd Generation Speakers Replacement, Speakers: passo 9, imagem 1 %32
    • This is where you will find the two speakers, after you have taken off the motherboard.
    I also would like to know know why it would be necessary to remove the board before removing the speakers? Nothing is prohibiting the speakers from being removed right away.
    Jennifer - Responder
  10. Motorola Moto G 2nd Generation Speakers Replacement: passo 10, imagem 1 %32 Motorola Moto G 2nd Generation Speakers Replacement: passo 10, imagem 2 %32
    • With the motherboard off, use tweezers to grab the top speaker.
    • Remove the speaker and replace it with a new one.
    Speaker not working after replacement, what is trick to setting the correct height of the speaker to make proper contact with the spring terminals?
    brian351max - Responder
  11. Motorola Moto G 2nd Generation Speakers Replacement: passo 11, imagem 1 %32 Motorola Moto G 2nd Generation Speakers Replacement: passo 11, imagem 2 %32
    • Use tweezers to replace the bottom speaker.
Conclusão
16 outras pessoas executaram este guia.
Jacob Garzini
Membro desde: 10/08/15
485 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 1-19, Maness Fall 2015 Membro de Cal Poly, Team 1-19, Maness Fall 2015
CPSU-MANESS-F15S1G19
Membros da 4
Autoria de 15 guias
10 comentários
Same problem happened to me when I replaced the screen, had to remove the speaker and when I put it back the upper (left) didn't work and the lower (right) had terrible distortion noise. playing a little with the upper speaker location made it work but with noise as well.
The phone is useless without this speaker, it's pretty shame that nobody pays attention to this point in their guides.
Tal wns - Responder
Have you fixed your speakers? Did you at least discovered why it happened?
Erick Carvalho Campos -
I had a similar problem after replacing my battery. After I put the phone back together, my bottom speaker was not working. I went ahead and ordered a speaker to replace the one that was not working, and it still didn't work. Knowing that my top speaker was working okay, I replaced the top speaker to see if the new one I received was working, and it didn't work on top either. As a matter of fact, I put back the original top speaker that was working okay, and now it doesn't work. So now neither one of them are working. I have to use earphones to hear my phone. I don't know what happened. The instructions to replace the speakers are not that difficult.
Does anyone have any suggestions on what I should do? I'm not ready to give up my phone just yet.
Betsey -
I replaced the speakers recently and it is not recessary to remove the motherboard to replace them.
Dan Eff - Responder
To corroborate with the other commenters: removing the motherboard is unnecessary. The speakers are only held in with a small ring of adhesive, which can easily be pried out. Additionally, the two speakers are identical.
Gavin Lochtefeld - Responder
Where can I get new speakers?
hlwjrnc - Responder
My moto g2 handset was burnt by short circuit and hence not opening only rather i may say that it was damaged. So, help me in repairing the handset.......
dipa10000 - Responder
I was having trouble removing the adhesive copper foil above the battery, most of it ripped and is ruined. How much will that affect phone performance?
Andy Ludowese - Responder
I had no sound after replacing my screen, but it's kind of working now after footering about, so I thought I'd share my thoughts for anyone in a similar predicament (I'm very much a chancer - happy to be corrected by someone who knows what they're on about!)
It seems like the speakers are connected via conductors on the back panel. I think the reason I had no sound after transferring them (along with everything else) to the new screen assembly was that the clear plastic/adhesive bit on the new thing wasn't thick enough, so the speaker wasn't being pressed against the back panel hard enough to make a good contact. I swapped this in from the old one and hey presto! A bit distorted, but working :)
So when performing Steps 10 and 11, make sure you don't leave a bit of transparent plastic behind - I'm not sure whether this is additional to the adhesive, or whether it's just turned hard in the meantime, but either way, the speaker needs to be at a certain height to work.
Ross McCrae - Responder
I have the same problem as others. After I replaced the display, the speaker don’t work anymore.
I’m buying new one but I need to know, Are the two speakers identical?
Giuseppe Geppo Cattaneo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 15,076
