Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
The buttons on the Moto G can sometimes get lost or misaligned. This guide will show you how to replace them or fix them.
Peças
Nenhum componente especificado.
  1. You can remove the outer cover on the back of the phone by using a plastic opening tool. After removal the inner back cover will be exposed as shown. This part is moderately difficult, especially if you've never taken the outer back cover off before this point. It may take you several tries, but please be patient. The cover is surprisingly flexible, but not enough to withstand a lot of pressure.
    • You can remove the outer cover on the back of the phone by using a plastic opening tool. After removal the inner back cover will be exposed as shown.
    • This part is moderately difficult, especially if you've never taken the outer back cover off before this point.
    • It may take you several tries, but please be patient. The cover is surprisingly flexible, but not enough to withstand a lot of pressure.
  2. Shut down the phone.
    • Shut down the phone.
    • Push SIM card until it pops out.
    • Remove SIM card.
  3. Using a T5 Torx screwdriver head, take out the 14 screws (3.5 mm diameter and 5 mm long) that hold the back plate in place. Make sure to keep all of the screws together, as they are very easily lost. The magnetic project mat or a container is a great way to keep all the little metal screws as well as other small metal pieces from being lost.
    • Using a T5 Torx screwdriver head, take out the 14 screws (3.5 mm diameter and 5 mm long) that hold the back plate in place.
    • Make sure to keep all of the screws together, as they are very easily lost.
    • The magnetic project mat or a container is a great way to keep all the little metal screws as well as other small metal pieces from being lost.
  4. Use the plastic opening tool to take out the inner back cover after all the screws have been removed. This will expose the motherboard and the attached battery. Take note that once the inner back cover is removed the volume and power buttons on the side can easily fall out or be removed.
    • Use the plastic opening tool to take out the inner back cover after all the screws have been removed.
    • This will expose the motherboard and the attached battery.
    • Take note that once the inner back cover is removed the volume and power buttons on the side can easily fall out or be removed.
  5. The buttons are extremely easy to replace and may fall out when opening the phone.
    • The buttons are extremely easy to replace and may fall out when opening the phone.
    • They are located on the left side when the front plate is facing down.
  6. Use a tool or your fingers to gently lift the button out of its socket. To replace, line the new button up in the socket and press down.
    • Use a tool or your fingers to gently lift the button out of its socket.
    • To replace, line the new button up in the socket and press down.
    • The buttons are not secured in anyway, so securing the back inner cover before turning the device over or jostling the device is a good idea. This will ensure buttons stay in place.
Conclusão
12 outras pessoas concluíram este guia.
Rebecca Montgomery
Membro desde: 25/09/2014
3.877 Reputação
6 Guias de autoria
Equipe
USF Tampa, Team 1-6, Brown Fall 2014 Membro de USF Tampa, Team 1-6, Brown Fall 2014
USFT-BROWN-F14S1G6
4 Membros
12 Guias de autoria
What if u don't have the tools to fix it
Qukwa - Responder
Step 4 "We highlighted buttons with pink circles for easy recognition." except that there's no pink circles. ummm?
Patrick Lee - Responder
Changes have been made since my group finished this project by others not associated with the group. I'm assuming an ifixit editor is trying to stay busy making necessary and unnecessary changes. Not sure why they removed highlighting circles.
Casey J.
Casey Jennelle -
Anyone could help me with where to buy these replacements? I can't find them anywhere in the net...
Juan Flb - Responder
Sir I want power on button
kishu - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 48
Duração total: 16,813
