Ir para o conteúdo principal
Motorola Moto E6 Motherboard Replacement
O que você precisa
  1. Motorola Moto E6 Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Motorola Moto E6 Motherboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Motherboard Replacement, Battery: passo 2, imagem 1 %32
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32
    • Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
  4. Motorola Moto E6 Motherboard Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tools to pry open the piece located at the top of the device.
    • Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
    • Pop off the piece above the battery compartment.
  5. Motorola Moto E6 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the two 1.1 mm T4 Torx screws from the bottom left and top right sides of the motherboard.
  6. Motorola Moto E6 Motherboard Replacement: passo 6, imagem 1 %32
    • Remove the two press fit cables at the bottom of the motherboard with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
    • After removing the cables, remove the motherboard from the phone by hand.
Conclusão
Uma outra pessoa concluiu este guia.
Matthew Zelten
Membro desde: 01/23/20
471 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S2-G3, White Winter 2020 Membro de Cal Poly, Team S2-G3, White Winter 2020
CPSU-WHITE-W20S2G3
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 1,380
