Ir para o conteúdo principal
Motorola Moto E6 Charging Dock Replacement
O que você precisa
  1. Motorola Moto E6 Charging Dock Replacement, Back Cover: passo 1, imagem 1 %32 Motorola Moto E6 Charging Dock Replacement, Back Cover: passo 1, imagem 2 %32
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Charging Dock Replacement, Battery: passo 2, imagem 1 %32
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Charging Dock Replacement, Charging Dock: passo 3, imagem 1 %32
    • Remove the seven 3.8 mm T4 screws on the piece located below the battery compartment.
  4. Motorola Moto E6 Charging Dock Replacement: passo 4, imagem 1 %32
    • Begin prying off the bottom piece with the opening tools on the divot located at the bottom left.
    • Work your way around the piece until it pops off.
  5. Motorola Moto E6 Charging Dock Replacement: passo 5, imagem 1 %32
    • Remove the press fit cable at the top of the charging dock with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
  6. Motorola Moto E6 Charging Dock Replacement: passo 6, imagem 1 %32
    • Remove the two 1.1 mm T4 Torx screws on the bottom right and top left sides of the charging dock.
    • Remove the charging dock by hand.
Conclusão
6 outras pessoas executaram este guia.
Matthew Zelten
Membro desde: 01/23/20
471 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S2-G3, White Winter 2020 Membro de Cal Poly, Team S2-G3, White Winter 2020
CPSU-WHITE-W20S2G3
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 32
Duração total: 2,833
