Ir para o conteúdo principal
Motorola Moto E4 Vibrator Replacement
O que você precisa
  1. Motorola Moto E4 Vibrator Replacement, Remove the rear cover: passo 1, imagem 1 %32 Motorola Moto E4 Vibrator Replacement, Remove the rear cover: passo 1, imagem 2 %32
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Vibrator Replacement, Charging Port: passo 2, imagem 1 %32
    • Remove the six 4mm screws from the bottom plastic cover with a Phillips driver bit.
  3. Motorola Moto E4 Vibrator Replacement: passo 3, imagem 1 %32
    • Gently pry the plastic cover from the phone using an iFixit opening tool.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Vibrator Replacement: passo 4, imagem 1 %32 Motorola Moto E4 Vibrator Replacement: passo 4, imagem 2 %32 Motorola Moto E4 Vibrator Replacement: passo 4, imagem 3 %32
    • Detach the two ribbon cable connectors from the top of the board using an iFixit opening tool.
    • Unplug the antenna cable connector from the board using an iFixit opening tool.
  5. Motorola Moto E4 Vibrator Replacement: passo 5, imagem 1 %32 Motorola Moto E4 Vibrator Replacement: passo 5, imagem 2 %32 Motorola Moto E4 Vibrator Replacement: passo 5, imagem 3 %32
    • Lift the vibrator out of its slot using the Halberd Spudger hook.
  6. Motorola Moto E4 Vibrator Replacement: passo 6, imagem 1 %32 Motorola Moto E4 Vibrator Replacement: passo 6, imagem 2 %32
    • Remove the two 4mm silver screws holding down the charging port board with Phillips bit.
  7. Motorola Moto E4 Vibrator Replacement: passo 7, imagem 1 %32 Motorola Moto E4 Vibrator Replacement: passo 7, imagem 2 %32
    • Place the iFixit opening tool underneath the board in between the micro USB port and the microphone.
    • Push forward and lift gently until the board lifts up.
    • Remove the charging port board from the device.
  8. Motorola Moto E4 Vibrator Replacement, Vibrator: passo 8, imagem 1 %32 Motorola Moto E4 Vibrator Replacement, Vibrator: passo 8, imagem 2 %32
    • Gently pull the vibrator upwards to remove the vibrator wires from the silver clasp holding the wires to the board.
    • Pull directly upwards to remove the vibrator from its connector.
Conclusão
Uma outra pessoa concluiu este guia.
Nate Tjepkema
Membro desde: 01/24/19
1.179 Reputação
7 Guias de autoria
Equipe
Cal Poly, Team S2-G4, White Winter 2019 Membro de Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 Membros
22 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 462
