Introdução
Use this guide to remove or replace your Moto E4 rear facing camera.
O que você precisa
Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
With the phone face down, lift the battery up by the labeled tab and remove it from the device.
Remove all nine 4 mm Phillips screws from the top plastic cover.
Gently pry up the plastic cover using a plastic opening tool.
Start by inserting the tool under the cover's right edge, as indicated by the first picture.
Pry up, and continue prying around the rest of the cover in a counter clockwise path.
Once loose, remove the plastic cover from the phone.
