Ir para o conteúdo principal
Motorola Moto E4 Plus Rear Camera Replacement
O que você precisa
  1. Motorola Moto E4 Plus Rear Camera Replacement, Remove the back cover: passo 1, imagem 1 %32 Motorola Moto E4 Plus Rear Camera Replacement, Remove the back cover: passo 1, imagem 2 %32 Motorola Moto E4 Plus Rear Camera Replacement, Remove the back cover: passo 1, imagem 3 %32
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Rear Camera Replacement: passo 2, imagem 1 %32 Motorola Moto E4 Plus Rear Camera Replacement: passo 2, imagem 2 %32
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Rear Camera Replacement, Midframe: passo 3, imagem 1 %32
    • Remove the eighteen 3.3 mm Phillips screws securing the midframe assembly.
  4. Motorola Moto E4 Plus Rear Camera Replacement: passo 4, imagem 1 %32 Motorola Moto E4 Plus Rear Camera Replacement: passo 4, imagem 2 %32
    • Remove the charging board cover.
  5. Motorola Moto E4 Plus Rear Camera Replacement: passo 5, imagem 1 %32 Motorola Moto E4 Plus Rear Camera Replacement: passo 5, imagem 2 %32 Motorola Moto E4 Plus Rear Camera Replacement: passo 5, imagem 3 %32
    • Remove the battery cover.
  6. Motorola Moto E4 Plus Rear Camera Replacement: passo 6, imagem 1 %32 Motorola Moto E4 Plus Rear Camera Replacement: passo 6, imagem 2 %32
    • Insert an opening pick underneath the bottom left corner of the motherboard cover.
    • Slide the opening pick between the cover and the second SIM tray to release the plastic clip.
  7. Motorola Moto E4 Plus Rear Camera Replacement: passo 7, imagem 1 %32 Motorola Moto E4 Plus Rear Camera Replacement: passo 7, imagem 2 %32
    • Insert an opening pick underneath the bottom right corner of the motherboard cover.
    • Use the opening pick to pry up the motherboard cover.
  8. Motorola Moto E4 Plus Rear Camera Replacement: passo 8, imagem 1 %32 Motorola Moto E4 Plus Rear Camera Replacement: passo 8, imagem 2 %32
    • Remove the motherboard cover.
  9. Motorola Moto E4 Plus Rear Camera Replacement, Battery Disconnect: passo 9, imagem 1 %32 Motorola Moto E4 Plus Rear Camera Replacement, Battery Disconnect: passo 9, imagem 2 %32
    • Use the edge of a spudger to pry up and disconnect the battery flex cable from the motherboard.
  10. Motorola Moto E4 Plus Rear Camera Replacement, Rear Camera: passo 10, imagem 1 %32 Motorola Moto E4 Plus Rear Camera Replacement, Rear Camera: passo 10, imagem 2 %32
    • Use a pair of tweezers to peel up the copper tape that covers the rear camera flex connector.
    • Fold the copper tape out of the way.
  11. Motorola Moto E4 Plus Rear Camera Replacement: passo 11, imagem 1 %32 Motorola Moto E4 Plus Rear Camera Replacement: passo 11, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the rear camera flex cable.
  12. Motorola Moto E4 Plus Rear Camera Replacement: passo 12, imagem 1 %32
    • Carefully remove the rear camera with a pair of tweezers.
Conclusão
If possible, turn on your phone and test your repair before reassembly.
5 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
202.579 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.722 guias
Um comentário
I want Moto e 4 + camera
Mubbu N - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,543
