Introdução
Follow this guide to remove and replace the battery for the Moto E4 Plus. Getting to the battery is not very difficult, but the battery itself is held onto the frame with strong adhesive. You will need to use high concentration (over 90%) isopropyl alcohol in order to loosen the battery from the phone.
If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Peças
Insert the edge of the spudger into the notch on the bottom right corner of the phone.
Twist the spudger to start releasing the back cover from the phone.
Slide the spudger along the bottom edge to separate the back cover from the phone.
Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
Twist the spudger to release the plastic clip.
Repeat the process for the clip near the top right corner of the phone.
Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
Remove the plastic midframe.
Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
Before you begin prying, note that the battery is held in place by two adhesive strips.
Insert an opening pick into the top right edge of the battery.
Push the opening pick in carefully until half of the pick is under the battery.
Insert another opening pick into the right edge, near the first opening pick.
Slide the opening pick down along the right edge to loosen the right adhesive strip.
If the slicing feels difficult, apply a few more drops of isopropyl alcohol into the edge, wait a minute for it to seep in, and try again.
Remove the battery.
Remove the old adhesive from the phone frame.
Apply new adhesive in the same general area as the old adhesive.
Lay the battery lightly in place. Check that the battery connector is properly aligned with its motherboard socket.
Press the battery firmly into the phone for thirty seconds.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto E4 Plus Answers community for help.
4 outras pessoas concluíram este guia.
Um comentário
You are a star. Spot on. I very much appreciate your contribution in breaking the monopoly of the bastards. They sold me the mobile without telling me the battery is fixed. I was about to send it for repair on their lab which could have cost me at least £200 if not more. £25 DHL . £45 just for looking into it . This is even before replacing the battery and the cost of labor. Take off my hat for you. Keep up the good work.
best regards
Sburgess
