Ir para o conteúdo principal
Motorola Moto E4 Motherboard Cover Replacement
O que você precisa
  1. Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: passo 1, imagem 1 %32 Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: passo 1, imagem 2 %32
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: passo 2, imagem 1 %32 Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: passo 2, imagem 2 %32
    • Remove all nine 4mm screws from the top plastic cover with a Phillips driver.
  3. Motorola Moto E4 Motherboard Cover Replacement: passo 3, imagem 1 %32 Motorola Moto E4 Motherboard Cover Replacement: passo 3, imagem 2 %32
    • Gently pry up the plastic cover from the gap between it and the phone edge.
    • Start on the right side as indicated by the first picture.
    • Continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
Conclusão
Nate Tjepkema
Membro desde: 01/24/19
1.179 Reputação
7 Guias de autoria
Equipe
Cal Poly, Team S2-G4, White Winter 2019 Membro de Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 Membros
22 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 503
