Ir para o conteúdo principal
Motorola Moto E4 Front Facing Camera Replacement
O que você precisa
  1. Motorola Moto E4 Front Facing Camera Replacement, Remove the rear cover: passo 1, imagem 1 %32 Motorola Moto E4 Front Facing Camera Replacement, Remove the rear cover: passo 1, imagem 2 %32
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Front Facing Camera Replacement, Motherboard Cover: passo 2, imagem 1 %32 Motorola Moto E4 Front Facing Camera Replacement, Motherboard Cover: passo 2, imagem 2 %32
    • Remove all nine 4mm screws from the top plastic cover with a Phillips driver.
  3. Motorola Moto E4 Front Facing Camera Replacement: passo 3, imagem 1 %32 Motorola Moto E4 Front Facing Camera Replacement: passo 3, imagem 2 %32
    • Gently pry up the plastic cover from the gap between it and the phone edge.
    • Start on the right side as indicated by the first picture.
    • Continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Front Facing Camera Replacement, Front Facing Camera: passo 4, imagem 1 %32 Motorola Moto E4 Front Facing Camera Replacement, Front Facing Camera: passo 4, imagem 2 %32
    • Detach the front facing cable ribbon connector using an iFixit opening tool and lift the camera out of position.
    • To completely remove the front facing camera from the phone, the copper colored adhesive must be torn. The camera will still with the adhesive removed, but there may be unknown side effects.
Conclusão
Nate Tjepkema
Membro desde: 01/24/19
1.179 Reputação
7 Guias de autoria
Equipe
Cal Poly, Team S2-G4, White Winter 2019 Membro de Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 Membros
22 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 369
