Ir para o conteúdo principal
Motorola Moto E Rear Facing Camera Replacement
O que você precisa
  1. Motorola Moto E Rear Facing Camera Replacement, Motherboard: passo 1, imagem 1 %32
    • Turn off the device before beginning.
    • To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
    • With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
    • You should hear a snapping sound at each corner.
  2. Motorola Moto E Rear Facing Camera Replacement: passo 2, imagem 1 %32
    • Unscrew the 14- 4mm screws using a T4 Torx driver head.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced.
  3. Motorola Moto E Rear Facing Camera Replacement: passo 3, imagem 1 %32
    • Using the same plastic opening tool as in step 1, once again pry up on the edges of the plastic back cover.
    • Be sure that all of the screws are out before lifting the cover. The plastic backing is fragile, and it may break.
  4. Motorola Moto E Rear Facing Camera Replacement: passo 4, imagem 1 %32
    • Gently lift the back plate away, exposing the motherboard. The battery will be stuck to the back of the cover, so be careful when lifting it off.
    • Do not touch the connections to the battery in the red square on the picture.
  5. Motorola Moto E Rear Facing Camera Replacement: passo 5, imagem 1 %32
    • Gently pull up on the red and black power cable to lift the connector out of the motherboard.
    • Move the battery and cover away from the motherboard.
  6. Motorola Moto E Rear Facing Camera Replacement: passo 6, imagem 1 %32
    • Unscrew the 3- 1mm screws using the T4 torx driver head.
  7. Motorola Moto E Rear Facing Camera Replacement: passo 7, imagem 1 %32
    • Lift up on the white plastic mount.
    • Pull the orange ribbon cable out gently.
  8. Motorola Moto E Rear Facing Camera Replacement: passo 8, imagem 1 %32 Motorola Moto E Rear Facing Camera Replacement: passo 8, imagem 2 %32
    • Gently pull the black ribbon cable out.
  9. Motorola Moto E Rear Facing Camera Replacement: passo 9, imagem 1 %32
    • Using the metal spudger, pry the motherboard away from the screen assembly.
  10. Motorola Moto E Rear Facing Camera Replacement, Rear Facing Camera: passo 10, imagem 1 %32
    • Use the plastic opening tool to pry the metal housing off.
  11. Motorola Moto E Rear Facing Camera Replacement: passo 11, imagem 1 %32
    • Remove the rubber cover on the camera by gently lifting it up.
  12. Motorola Moto E Rear Facing Camera Replacement: passo 12, imagem 1 %32
    • Use the same plastic opening tool to pry the camera assembly off.
    • Use the plastic opening tool on all four sides of the camera several times until it starts to come loose.
  13. Motorola Moto E Rear Facing Camera Replacement: passo 13, imagem 1 %32
    • Pull the camera assembly out.
    • Place the new camera assembly into the connector and press gently.
Conclusão
Alex Craig
Membro desde: 03/11/15
2.596 Reputação
Autoria de 5 guias
Equipe
Colorado Springs, Team 5-7, Panko Spring 2015 Membro de Colorado Springs, Team 5-7, Panko Spring 2015
UCCS-PANKO-S15S5G7
Membros da 2
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 3,163
