Introdução
Use this guide to replace the speaker on your Motorola Moto E 2nd Generation.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
O que você precisa
Once display is fully unglued from the frame, carefully lift it up and locate the display connector.
Using the same small plastic tool, carefully remove the yellow tape off the connector.
Now carefully undo the black connector lock by lifting it up in the direction of the red arrow.
Lastly slide the display cable off the connector. It should easily slide off, if not make sure the black lock is fully unlatched.
Now that the display is out, remove the aluminum shield off the motherboard.
Unscrew the single 4mm screw located on the top using a T4 Torx bit.
After screw is out, gently remove the aluminum shield off the motherboard.
10 outras pessoas executaram este guia.
3 comentários
Olá André. Gostaria de saber se aquela peça a direita do earpiece speaker é outro falante.
Questiono pq o meu Moto E2 apresenta um som meio chiado nas ligações, porém no viva voz ou reproduzindo mídia o som é limpo, normal.
Obrigado.
