Ir para o conteúdo principal
Motorola MOTO W755 Cell Phone Speaker Replacement
O que você precisa
  1. Motorola MOTO W755 Cell Phone Speaker Replacement, Top Panel: passo 1, imagem 1 %32 Motorola MOTO W755 Cell Phone Speaker Replacement, Top Panel: passo 1, imagem 2 %32 Motorola MOTO W755 Cell Phone Speaker Replacement, Top Panel: passo 1, imagem 3 %32
    • Use the plastic opening tool to pull peel back screen cover.
    • Gently peel back the screen cover from the speaker slit.
    • Using the T6 Torx-screwdriver, remove the four 4.3 mm screws from the top panel.
  2. Motorola MOTO W755 Cell Phone Speaker Replacement: passo 2, imagem 1 %32 Motorola MOTO W755 Cell Phone Speaker Replacement: passo 2, imagem 2 %32 Motorola MOTO W755 Cell Phone Speaker Replacement: passo 2, imagem 3 %32
    • Using the flat end of the plastic opening tool, insert it underneath the plastic cover on the top right corner.
    • Move the opening tool around the phone counter clockwise.
    • Pop the plastic cover off by twisting the plastic covering tool.
  3. Motorola MOTO W755 Cell Phone Speaker Replacement: passo 3, imagem 1 %32 Motorola MOTO W755 Cell Phone Speaker Replacement: passo 3, imagem 2 %32
    • Using a flat head screwdriver, insert it between the metal logic board casing and the top portion of the phone
    • Move the plastic opening tool around the phone until part of the casting is popped off.
    • You will need to pop in the four plastic fasteners individually from the metal casing to remove it
    • Be careful not to rip the cable ribbons that are attached to the logic board and casing
  4. Motorola MOTO W755 Cell Phone Speaker Replacement: passo 4, imagem 1 %32
    • Use the flat end of the plastic opening tool to unclip the cable ribbon from the logic board
  5. Motorola MOTO W755 Cell Phone Speaker Replacement: passo 5, imagem 1 %32
    • You now have the top panel completely detached.
  6. Motorola MOTO W755 Cell Phone Speaker Replacement, Speaker: passo 6, imagem 1 %32 Motorola MOTO W755 Cell Phone Speaker Replacement, Speaker: passo 6, imagem 2 %32
    • Flip the top portion of the phone so that the back is facing you.
    • Using the flat end of the plastic opening tool, pry the speaker off the back of the phone.
Conclusão
Roberta Glenn
Membro desde: 07/11/12
43 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 1-3, Regan SU 2012 Membro de Cal Poly, Team 1-3, Regan SU 2012
CPSU-REGAN-SU12S1G3
2 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 1,667
