Ir para o conteúdo principal
Motorola MOTO W755 Cell Phone Main Logic Board Replacement
O que você precisa
  1. Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Battery: passo 1, imagem 1 %32 Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Battery: passo 1, imagem 2 %32
    • Using your finger, press down on the clip holding the back cover on
    • Pull the back cover off.
  2. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: passo 2, imagem 1 %32 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: passo 2, imagem 2 %32
    • Place thumb and index finger in the spaces on either side of the battery.
    • Pull battery out.
  3. Motorola MOTO W755 Cell Phone Main Logic Board Replacement, Main Logic Board: passo 3, imagem 1 %32
    • Using the T5 Torx-screwdriver, remove the four 5.5 mm screws on the back panel.
  4. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: passo 4, imagem 1 %32 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: passo 4, imagem 2 %32
    • Using a plastic opening tool, carefully peel back the rubber strip located at the bottom of the keypad
    • Remove the two T5 Torx-screws underneath the rubber strip using the T5 Torx-screwdriver
  5. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: passo 5, imagem 1 %32 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: passo 5, imagem 2 %32 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: passo 5, imagem 3 %32
    • Using the flat end of the plastic opening tool, insert it in the gap between the charging port and plastic at the bottom left side of the phone.
    • Slide the opening tool around the phone clockwise until you reach the audio port.
    • Twist the opening tool until the plastic pops off from the body of the phone. This make require a small amount of force.
  6. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: passo 6, imagem 1 %32
    • Remove the plastic covering completely from the body of the phone.
  7. Motorola MOTO W755 Cell Phone Main Logic Board Replacement: passo 7, imagem 1 %32 Motorola MOTO W755 Cell Phone Main Logic Board Replacement: passo 7, imagem 2 %32
    • Using the plastic opening tool, carefully unclip the cable ribbon from the main logic board. Be sure not to tear it because the flex is very fragile.
    • Remove the main logic board.
Conclusão
C Miller
Membro desde: 06/25/12
56 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 1-3, Regan SU 2012 Membro de Cal Poly, Team 1-3, Regan SU 2012
CPSU-REGAN-SU12S1G3
2 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 1,683
