Ir para o conteúdo principal
Motorola MOTO W755 Cell Phone Camera Replacement
O que você precisa
  1. Motorola MOTO W755 Cell Phone Camera Replacement, Battery: passo 1, imagem 1 %32 Motorola MOTO W755 Cell Phone Camera Replacement, Battery: passo 1, imagem 2 %32
    • Using your finger, press down on the clip holding the back cover on
    • Pull the back cover off.
    Pergunte ao FixBot
    Comentar
  2. Motorola MOTO W755 Cell Phone Camera Replacement: passo 2, imagem 1 %32 Motorola MOTO W755 Cell Phone Camera Replacement: passo 2, imagem 2 %32
    • Place thumb and index finger in the spaces on either side of the battery.
    • Pull battery out.
    Pergunte ao FixBot
    Comentar
  3. Motorola MOTO W755 Cell Phone Camera Replacement, Top Panel: passo 3, imagem 1 %32 Motorola MOTO W755 Cell Phone Camera Replacement, Top Panel: passo 3, imagem 2 %32 Motorola MOTO W755 Cell Phone Camera Replacement, Top Panel: passo 3, imagem 3 %32
    • Use the plastic opening tool to pull peel back screen cover.
    • Gently peel back the screen cover from the speaker slit.
    • Using the T6 Torx-screwdriver, remove the four 4.3 mm screws from the top panel.
    Pergunte ao FixBot
    Comentar
  4. Motorola MOTO W755 Cell Phone Camera Replacement: passo 4, imagem 1 %32 Motorola MOTO W755 Cell Phone Camera Replacement: passo 4, imagem 2 %32 Motorola MOTO W755 Cell Phone Camera Replacement: passo 4, imagem 3 %32
    • Using the flat end of the plastic opening tool, insert it underneath the plastic cover on the top right corner.
    • Move the opening tool around the phone counter clockwise.
    • Pop the plastic cover off by twisting the plastic covering tool.
    Pergunte ao FixBot
    Comentar
  5. Motorola MOTO W755 Cell Phone Camera Replacement: passo 5, imagem 1 %32 Motorola MOTO W755 Cell Phone Camera Replacement: passo 5, imagem 2 %32
    • Using a flat head screwdriver, insert it between the metal logic board casing and the top portion of the phone
    • Move the plastic opening tool around the phone until part of the casting is popped off.
    • You will need to pop in the four plastic fasteners individually from the metal casing to remove it
    • Be careful not to rip the cable ribbons that are attached to the logic board and casing
    Pergunte ao FixBot
    Comentar
  6. Motorola MOTO W755 Cell Phone Camera Replacement: passo 6, imagem 1 %32
    • Use the flat end of the plastic opening tool to unclip the cable ribbon from the logic board
    Pergunte ao FixBot
    Comentar
  7. Motorola MOTO W755 Cell Phone Camera Replacement: passo 7, imagem 1 %32
    • You now have the top panel completely detached.
    Pergunte ao FixBot
    Comentar
  8. Motorola MOTO W755 Cell Phone Camera Replacement, Camera: passo 8, imagem 1 %32
    • Using the plastic opening tool, peel back the plastic cover that is glued on top of the camera lens.
    Pergunte ao FixBot
    Comentar
  9. Motorola MOTO W755 Cell Phone Camera Replacement: passo 9, imagem 1 %32 Motorola MOTO W755 Cell Phone Camera Replacement: passo 9, imagem 2 %32
    • Using the plastic opening tool, gently push the camera out from the front.
    • Part of the foam holding the camera will rip from the adhesive.
    Pergunte ao FixBot
    Comentar
Conclusão
C Miller
Membro desde: 06/25/12
56 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 1-3, Regan SU 2012 Membro de Cal Poly, Team 1-3, Regan SU 2012
CPSU-REGAN-SU12S1G3
2 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 38
Ao todo: 1,440
