Ir para o conteúdo principal
Motorola MC5590 Keyboard Replacement
O que você precisa
  1. Motorola MC5590 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Push in the battery release button.
    Pergunte ao FixBot
    Comentar
  2. Motorola MC5590 Keyboard Replacement: passo 2, imagem 1 %32
    • Pull out battery.
    Pergunte ao FixBot
    Comentar
  3. Motorola MC5590 Keyboard Replacement, Keyboard: passo 3, imagem 1 %32 Motorola MC5590 Keyboard Replacement, Keyboard: passo 3, imagem 2 %32
    • Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
    Pergunte ao FixBot
    Comentar
  4. Motorola MC5590 Keyboard Replacement: passo 4, imagem 1 %32 Motorola MC5590 Keyboard Replacement: passo 4, imagem 2 %32 Motorola MC5590 Keyboard Replacement: passo 4, imagem 3 %32
    • Remove the four 1cm Phillips #0 screws from the top and bottom of the phone.
    Pergunte ao FixBot
    Comentar
  5. Motorola MC5590 Keyboard Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
    Pergunte ao FixBot
    Comentar
  6. Motorola MC5590 Keyboard Replacement: passo 6, imagem 1 %32 Motorola MC5590 Keyboard Replacement: passo 6, imagem 2 %32
    • Remove the eight 4mm Phillips #00 screws from the keyboard cover.
    Pergunte ao FixBot
    Comentar
  7. Motorola MC5590 Keyboard Replacement: passo 7, imagem 1 %32
    • Remove the keyboard cover.
    Pergunte ao FixBot
    Comentar
  8. Motorola MC5590 Keyboard Replacement: passo 8, imagem 1 %32 Motorola MC5590 Keyboard Replacement: passo 8, imagem 2 %32 Motorola MC5590 Keyboard Replacement: passo 8, imagem 3 %32
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
    Pergunte ao FixBot
    Comentar
  9. Motorola MC5590 Keyboard Replacement: passo 9, imagem 1 %32 Motorola MC5590 Keyboard Replacement: passo 9, imagem 2 %32
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Remove the keyboard from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Tyler Jean
Membro desde: 02/22/18
555 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G6, Cagle Spring 2018 Membro de USF Tampa, Team S1-G6, Cagle Spring 2018
USFT-CAGLE-S18S1G6
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 506
