Ir para o conteúdo principal
Motorola MC5590 Internal Antenna Replacement
O que você precisa
  1. Motorola MC5590 Internal Antenna Replacement, Battery: passo 1, imagem 1 %32
    • Push in the battery release button.
  2. Motorola MC5590 Internal Antenna Replacement: passo 2, imagem 1 %32
    • Pull out battery.
  3. Motorola MC5590 Internal Antenna Replacement, Keyboard: passo 3, imagem 1 %32 Motorola MC5590 Internal Antenna Replacement, Keyboard: passo 3, imagem 2 %32
    • Remove the two rubber plugs on the top of the device by pushing them up and out of the phone.
  4. Motorola MC5590 Internal Antenna Replacement: passo 4, imagem 1 %32 Motorola MC5590 Internal Antenna Replacement: passo 4, imagem 2 %32 Motorola MC5590 Internal Antenna Replacement: passo 4, imagem 3 %32
    • Remove the four 1cm Phillips #0 screws from the top and bottom of the phone.
  5. Motorola MC5590 Internal Antenna Replacement: passo 5, imagem 1 %32
    • Use a plastic opening tool to remove the keyboard cover by prying up on its perimeter.
  6. Motorola MC5590 Internal Antenna Replacement: passo 6, imagem 1 %32 Motorola MC5590 Internal Antenna Replacement: passo 6, imagem 2 %32
    • Remove the eight 4mm Phillips #00 screws from the keyboard cover.
  7. Motorola MC5590 Internal Antenna Replacement: passo 7, imagem 1 %32
    • Remove the keyboard cover.
  8. Motorola MC5590 Internal Antenna Replacement: passo 8, imagem 1 %32 Motorola MC5590 Internal Antenna Replacement: passo 8, imagem 2 %32 Motorola MC5590 Internal Antenna Replacement: passo 8, imagem 3 %32
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Pull the ribbon cable out of the socket.
  9. Motorola MC5590 Internal Antenna Replacement: passo 9, imagem 1 %32 Motorola MC5590 Internal Antenna Replacement: passo 9, imagem 2 %32
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Remove the keyboard from the device.
  10. Motorola MC5590 Internal Antenna Replacement, Speaker: passo 10, imagem 1 %32 Motorola MC5590 Internal Antenna Replacement, Speaker: passo 10, imagem 2 %32
    • Pull the black rubber tabs up gently and remove them.
  11. Motorola MC5590 Internal Antenna Replacement: passo 11, imagem 1 %32 Motorola MC5590 Internal Antenna Replacement: passo 11, imagem 2 %32
    • Using your finger, or spudger, push the motherboard out from the bottom.
  12. Motorola MC5590 Internal Antenna Replacement: passo 12, imagem 1 %32 Motorola MC5590 Internal Antenna Replacement: passo 12, imagem 2 %32
    • Remove the three Phillips #00 screws from the motherboard:
    • Two 3mm screws.
    • One 1mm screw.
  13. Motorola MC5590 Internal Antenna Replacement: passo 13, imagem 1 %32 Motorola MC5590 Internal Antenna Replacement: passo 13, imagem 2 %32
    • Disconnect the speaker from the motherboard.
  14. Motorola MC5590 Internal Antenna Replacement, LCD Screen: passo 14, imagem 1 %32 Motorola MC5590 Internal Antenna Replacement, LCD Screen: passo 14, imagem 2 %32 Motorola MC5590 Internal Antenna Replacement, LCD Screen: passo 14, imagem 3 %32
    • Remove the the 3mm Phillips #00 screws from the flex cable cover and antenna.
    • Remove the antenna.
    • Remove the flex cable cover.
  15. Motorola MC5590 Internal Antenna Replacement: passo 15, imagem 1 %32 Motorola MC5590 Internal Antenna Replacement: passo 15, imagem 2 %32
    • Remove the five 3mm Phillips #00 screws from the motherboard.
  16. Motorola MC5590 Internal Antenna Replacement: passo 16, imagem 1 %32 Motorola MC5590 Internal Antenna Replacement: passo 16, imagem 2 %32
    • Remove the scanner ribbon cable by pulling straight up and out.
  17. Motorola MC5590 Internal Antenna Replacement: passo 17, imagem 1 %32 Motorola MC5590 Internal Antenna Replacement: passo 17, imagem 2 %32
    • Flip open the motherboard and the LCD screen.
    • Open the LCD connector and remove the cable.
    • Pull the LCD Screen and its metal bracket apart.
  18. Motorola MC5590 Internal Antenna Replacement, Internal Antenna: passo 18, imagem 1 %32 Motorola MC5590 Internal Antenna Replacement, Internal Antenna: passo 18, imagem 2 %32
    • Remove the antenna connector (red box).
    • This is a snap-on connector, which can be removed by applying a gentle pull straight up from the motherboard.
Conclusão
Tyler Jean
Membro desde: 02/22/18
555 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G6, Cagle Spring 2018 Membro de USF Tampa, Team S1-G6, Cagle Spring 2018
USFT-CAGLE-S18S1G6
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 296
