Introdução
This guide will show users how to take apart the camera housing in order to replace the speaker.
  1. Remove two 5 mm Phillips #1 screws from the bottom of the camera stand. Remove two 5 mm Phillips #1 screws from the bottom of the camera stand.
    • Remove two 5 mm Phillips #1 screws from the bottom of the camera stand.
  2. Use a nylon spudger to remove the casing.
    • Use a nylon spudger to remove the casing.
  3. Remove the two 5 mm Phillips #1 screws attached to the black plastic under the casing.
    • Remove the two 5 mm Phillips #1 screws attached to the black plastic under the casing.
  4. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  5. Remove the black circular plastic part. Remove the black circular plastic part.
    • Remove the black circular plastic part.
  6. Remove the white plastic wire housing beneath the black plastic.
    • Remove the white plastic wire housing beneath the black plastic.
  7. Now, remove the bottom of the stand by pulling it from the camera. Now, remove the bottom of the stand by pulling it from the camera.
    • Now, remove the bottom of the stand by pulling it from the camera.
  8. Remove the Phillips #1 screws on the back of the device. Use a nylon spudger to remove the casing. This will separate the frontside of the camera from the backside. Use a nylon spudger to remove the casing. This will separate the frontside of the camera from the backside.
    • Remove the Phillips #1 screws on the back of the device.
    • Use a nylon spudger to remove the casing. This will separate the frontside of the camera from the backside.
  9. Now locate the brackets by the speaker on the frontside of the camera and use the metal spudger to carefully disconnect from casing. Continue to use the metal spudger to carefully disconnect the remaining brackets from the casing.
    • Now locate the brackets by the speaker on the frontside of the camera and use the metal spudger to carefully disconnect from casing.
    • Continue to use the metal spudger to carefully disconnect the remaining brackets from the casing.
  10. Using the soldering iron, desolder the speaker wires that are attached to the circuit board. Use caution while handling the soldering iron. This tool gets very hot!
    • Using the soldering iron, desolder the speaker wires that are attached to the circuit board.
    • Use caution while handling the soldering iron. This tool gets very hot!
    • After desoldering the speaker wires, remove the wires from the circuit board.
    • Thread the wires from the new speaker wires through the holes in the circuit board. Using the soldering iron, re-solder the wires to the circuit board.
Conclusão
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 40
