Ir para o conteúdo principal
Motorola MBP667CONNECT Battery Replacement
O que você precisa
  1. Motorola MBP667CONNECT Battery Replacement, Battery: passo 1, imagem 1 %32
    • The battery casing is on the back of the monitor housing.
  2. Motorola MBP667CONNECT Battery Replacement: passo 2, imagem 1 %32 Motorola MBP667CONNECT Battery Replacement: passo 2, imagem 2 %32
    • Notice the little crevice at the bottom of the baby monitor. This is how the lid is removed. Simply put pressure with your finger to the crevice and lift.
    • Remove the battery casing lid from the back of the monitor housing.
  3. Motorola MBP667CONNECT Battery Replacement: passo 3, imagem 1 %32
    • There is a plastic part connecting the wires of the battery to the device.
    • Disconnect the battery wiring from the monitor battery connection.
  4. Motorola MBP667CONNECT Battery Replacement: passo 4, imagem 1 %32
    • Remove and discard the old battery and replace it with a new battery.
Conclusão
Kyle Kramer
Membro desde: 01/16/19
255 Reputação
Autoria de 2 guias
Um comentário
just bought the battery linked and it has a slightly different, incompatible fitting. If i find one that works I’ll post…
Alex Chassy - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 30
Duração total: 5,015
