Ir para o conteúdo principal
Motorola Lapdock 100 Keyboard Replacement
O que você precisa
  1. Motorola Lapdock 100 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Motorola Lapdock 100 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32
    • To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed. You do not need to remove any keys to unclip the keyboard.
  2. Motorola Lapdock 100 Keyboard Replacement: passo 2, imagem 1 %32 Motorola Lapdock 100 Keyboard Replacement: passo 2, imagem 2 %32 Motorola Lapdock 100 Keyboard Replacement: passo 2, imagem 3 %32
    • You can use the a small metal spudger to depress each tab to avoid scratching the keyboard.
  3. Motorola Lapdock 100 Keyboard Replacement: passo 3, imagem 1 %32 Motorola Lapdock 100 Keyboard Replacement: passo 3, imagem 2 %32
    • Flip up white clip holding the ribbon cable on the contact as shown in the two pictures and then gently disconnect the ribbon cable.
  4. Motorola Lapdock 100 Keyboard Replacement: passo 4, imagem 1 %32
    • Remove the keyboard
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 410
