Ir para o conteúdo principal
Motorola Krzr K1m keyboard repalcement
O que você precisa
  1. Motorola Krzr K1m keyboard repalcement, Keypad: passo 1, imagem 1 %32 Motorola Krzr K1m keyboard repalcement, Keypad: passo 1, imagem 2 %32
    • Remove the battery with your fingers by pulling the battery from the top corners labeled "Pull Here" located on the left and right side of the top of the battery.
    • Remove the battery.
  2. Motorola Krzr K1m keyboard repalcement: passo 2, imagem 1 %32 Motorola Krzr K1m keyboard repalcement: passo 2, imagem 2 %32 Motorola Krzr K1m keyboard repalcement: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Spudger
    $3.99
    Comprar
    • To begin detaching the battery dock, unscrew the 4 black screws on each corner of the phone with the T5 Torx Screwdriver.
    • Lift up the battery dock where the hinges are located. Carefully insert the T5 Torx Screwdriver in between the battery dock and the back plate of the battery. (See the picture to locate the hinges)
    • Remove the battery dock by popping it up with The Spudger.
  3. Motorola Krzr K1m keyboard repalcement: passo 3, imagem 1 %32 Motorola Krzr K1m keyboard repalcement: passo 3, imagem 2 %32 Motorola Krzr K1m keyboard repalcement: passo 3, imagem 3 %32
    Comprar
    • To remove the chip board, first unplug the flex cable from the logic board with tweezers.
    • Lift up the logic board from the bottom flip with your fingers.
    • Remove the logic board.
  4. Motorola Krzr K1m keyboard repalcement: passo 4, imagem 1 %32 Motorola Krzr K1m keyboard repalcement: passo 4, imagem 2 %32
    • Gently pop off the keypad with your fingers.
    • Once the keypad is removed, follow all of the steps in reverse order to replace the old keypad with the new keypad.
Conclusão
Equipe
Cal Poly, Team 11-1, Forte Winter 2010 Membro de Cal Poly, Team 11-1, Forte Winter 2010
CPSU-FORTE-W10S11G1
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 4,421
