Ir para o conteúdo principal
Motorola Krzr K1m Battery Replacement
  1. Motorola Krzr K1m Battery Replacement, Battery: passo 1, imagem 1 %32 Motorola Krzr K1m Battery Replacement, Battery: passo 1, imagem 2 %32
    • Push down on the silver tab located at the top center of the back of the Motorola K1m cellphone.
  2. Motorola Krzr K1m Battery Replacement: passo 2, imagem 1 %32
    • While pushing down on the silver tab, slide the back cover towards the silver tab.
    • Remove the back cover.
  3. Motorola Krzr K1m Battery Replacement: passo 3, imagem 1 %32
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Replace the old battery with the new battery.
    • Follow all of the steps to remove the battery in reverse order to reassemble.
Conclusão
Equipe
Cal Poly, Team 11-1, Forte Winter 2010 Membro de Cal Poly, Team 11-1, Forte Winter 2010
CPSU-FORTE-W10S11G1
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 5,547
