Ir para o conteúdo principal
Motorola E815 Keypad Replacement
O que você precisa
  1. Motorola E815 Keypad Replacement, Battery: passo 1, imagem 1 %32
    • Locate the back cover release slide.
    • Use your finger to slide it down.
  2. Motorola E815 Keypad Replacement: passo 2, imagem 1 %32
    • Remove the back cover by pulling it away from the phone.
  3. Motorola E815 Keypad Replacement: passo 3, imagem 1 %32 Motorola E815 Keypad Replacement: passo 3, imagem 2 %32
    • Locate the battery removal slot.
    • Use your finger to pull the battery out from the top.
    • Remove the battery.
  4. Motorola E815 Keypad Replacement, Disassembling Motorola E815 Antenna: passo 4, imagem 1 %32
    • Locate the antenna port on the top of the phone.
  5. Motorola E815 Keypad Replacement: passo 5, imagem 1 %32 Motorola E815 Keypad Replacement: passo 5, imagem 2 %32
    • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
    • Pull the apparatus up and out of the phone.
  6. Motorola E815 Keypad Replacement, Keypad: passo 6, imagem 1 %32
    • Locate the two screws on the backside of the phone.
    • Unscrew the two screws using a T6 Screwdriver.
  7. Motorola E815 Keypad Replacement: passo 7, imagem 1 %32 Motorola E815 Keypad Replacement: passo 7, imagem 2 %32 Motorola E815 Keypad Replacement: passo 7, imagem 3 %32
    • Gently pull the top section of the phone upwards until you feel some resistance.
    • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
    • Using tweezers, gently pry the connector from the circuit board.
    • Carefully detach the two sections of the phone.
  8. Motorola E815 Keypad Replacement: passo 8, imagem 1 %32 Motorola E815 Keypad Replacement: passo 8, imagem 2 %32 Motorola E815 Keypad Replacement: passo 8, imagem 3 %32
    • Using the blue pry tool, carefully pull the keypad frame away from the keypad.
    • Gently remove the keypad frame from the keypad.
    • Lift the silicone keypad cover off.
  9. Motorola E815 Keypad Replacement: passo 9, imagem 1 %32 Motorola E815 Keypad Replacement: passo 9, imagem 2 %32
    • Rotate the phone around so that you are looking at the battery cavity.
    • Locate the screws on the bottom base of the phone.
  10. Motorola E815 Keypad Replacement: passo 10, imagem 1 %32 Motorola E815 Keypad Replacement: passo 10, imagem 2 %32
    • Rotate the phone back to the front side.
    • Slowly lift the bottom portion of the keypad off of the phone until you feel resistance.
  11. Motorola E815 Keypad Replacement: passo 11, imagem 1 %32 Motorola E815 Keypad Replacement: passo 11, imagem 2 %32 Motorola E815 Keypad Replacement: passo 11, imagem 3 %32
    • Using tweezers, carefully detach the yellow connector strip from the circuit board by lifting up.
    • Separate the keypad from the circuit board.
Conclusão
Uma outra pessoa concluiu este guia.
Zoie E
Membro desde: 01/12/11
603 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 14-8, Forte Winter 2011 Membro de Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
Membros da 5
Autoria de 5 guias
2 comentários
We should have a motherboard replacement.
Santi12008 - Responder
We need to fullify more this content.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 2,085
