Ir para o conteúdo principal
Motorola E815 Front Screen Replacement
O que você precisa
  1. Motorola E815 Front Screen Replacement, Battery: passo 1, imagem 1 %32
    • Locate the back cover release slide.
    • Use your finger to slide it down.
    Pergunte ao FixBot
    Comentar
  2. Motorola E815 Front Screen Replacement: passo 2, imagem 1 %32
    • Remove the back cover by pulling it away from the phone.
    Pergunte ao FixBot
    Comentar
  3. Motorola E815 Front Screen Replacement: passo 3, imagem 1 %32 Motorola E815 Front Screen Replacement: passo 3, imagem 2 %32
    • Locate the battery removal slot.
    • Use your finger to pull the battery out from the top.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  4. Motorola E815 Front Screen Replacement, Disassembling Motorola E815 Antenna: passo 4, imagem 1 %32
    • Locate the antenna port on the top of the phone.
    Pergunte ao FixBot
    Comentar
  5. Motorola E815 Front Screen Replacement: passo 5, imagem 1 %32 Motorola E815 Front Screen Replacement: passo 5, imagem 2 %32
    • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
    • Pull the apparatus up and out of the phone.
    Pergunte ao FixBot
    Comentar
  6. Motorola E815 Front Screen Replacement, Front Screen: passo 6, imagem 1 %32 Motorola E815 Front Screen Replacement, Front Screen: passo 6, imagem 2 %32 Motorola E815 Front Screen Replacement, Front Screen: passo 6, imagem 3 %32
    • Locate the two screws on the backside of the phone.
    • Unscrew the two screws using your T6 screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Motorola E815 Front Screen Replacement: passo 7, imagem 1 %32 Motorola E815 Front Screen Replacement: passo 7, imagem 2 %32 Motorola E815 Front Screen Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Grasp the top of the phone near the speaker.
    • Gently pull the top section of the phone upwards until you feel some resistance.
    • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
    • Using tweezers, gently pry the connector from the circuit board.
    • Detach the top section of the phone from the keypad section.
    Pergunte ao FixBot
    Comentar
  8. Motorola E815 Front Screen Replacement: passo 8, imagem 1 %32 Motorola E815 Front Screen Replacement: passo 8, imagem 2 %32
    • Carefully insert the blue pry tool into the notch between the two halves of the top section of the phone.
    • Gently pry the two halves apart.
    Pergunte ao FixBot
    Comentar
  9. Motorola E815 Front Screen Replacement: passo 9, imagem 1 %32
    • Rotate the top section of the phone around so that you are looking at the outer screen.
    • Disconnect the cover from the outer screen side of the phone.
    Pergunte ao FixBot
    Comentar
  10. Motorola E815 Front Screen Replacement: passo 10, imagem 1 %32 Motorola E815 Front Screen Replacement: passo 10, imagem 2 %32 Motorola E815 Front Screen Replacement: passo 10, imagem 3 %32
    • Rotate the top section of the phone around so you are looking at the large screen.
    • Using your fingers, lift the protector off of the screen.
    Pergunte ao FixBot
    Comentar
  11. Motorola E815 Front Screen Replacement: passo 11, imagem 1 %32
    • Using the blue pry tool, gently remove the screen cover.
    • Since it is glued into place, it may take some maneuvering to remove.
    Pergunte ao FixBot
    Comentar
  12. Motorola E815 Front Screen Replacement: passo 12, imagem 1 %32 Motorola E815 Front Screen Replacement: passo 12, imagem 2 %32 Motorola E815 Front Screen Replacement: passo 12, imagem 3 %32
    • Turn the phone so that you can see the side metal clasps.
    • Using the blue lifter tool, snap the metal clasps off of screen body.
    • Proceed to snap all four corners of the metal cover off of the screen body.
    Pergunte ao FixBot
    Comentar
  13. Motorola E815 Front Screen Replacement: passo 13, imagem 1 %32 Motorola E815 Front Screen Replacement: passo 13, imagem 2 %32
    • Using tweezers, gently detach the brown connecting strip from the back of the screen.
    • Separate the screen from the phone frame.
    • The front screen can now be accessed and replaced!
    Pergunte ao FixBot
    Comentar
Conclusão
Zoie E
Membro desde: 01/12/11
603 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 14-8, Forte Winter 2011 Membro de Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 37
Ao todo: 2,674
