Introdução
This guide shows you how to replace the camera as it may be damaged or malfunctioning. The removal of the camera itself is simple, but getting there can be tricky because of the motherboard. Carefully follow guide. Tools are required for this.
O que você precisa
Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
Using tweezers, remove cable from motherboard.
Um comentário
how do u get it back on when it dose not come back on
brianna
