Ir para o conteúdo principal
Motorola Droid X2 Motherboard Replacement
O que você precisa
  1. Motorola Droid X2 Motherboard Replacement, Battery: passo 1, imagem 1 %32 Motorola Droid X2 Motherboard Replacement, Battery: passo 1, imagem 2 %32 Motorola Droid X2 Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Slide the plastic case off of the back of the phone, exposing the battery.
  2. Motorola Droid X2 Motherboard Replacement: passo 2, imagem 1 %32 Motorola Droid X2 Motherboard Replacement: passo 2, imagem 2 %32 Motorola Droid X2 Motherboard Replacement: passo 2, imagem 3 %32
    • Pull up on the red battery release tab and pull the battery out of the phone.
  3. Motorola Droid X2 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 Motorola Droid X2 Motherboard Replacement, Motherboard: passo 3, imagem 2 %32
    • Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
    • Be careful to not strip any screws.
  4. Motorola Droid X2 Motherboard Replacement: passo 4, imagem 1 %32 Motorola Droid X2 Motherboard Replacement: passo 4, imagem 2 %32 Motorola Droid X2 Motherboard Replacement: passo 4, imagem 3 %32
    • Using a prying tool, snap off the front casing on the top and bottom of the phone.
    • Be careful not to lose the small rubber piece that sits over the microphone.
  5. Motorola Droid X2 Motherboard Replacement: passo 5, imagem 1 %32 Motorola Droid X2 Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the circled screws using a T-5 torques.. These screws should be 5.8 millimeters in length.
  6. Motorola Droid X2 Motherboard Replacement: passo 6, imagem 1 %32 Motorola Droid X2 Motherboard Replacement: passo 6, imagem 2 %32 Motorola Droid X2 Motherboard Replacement: passo 6, imagem 3 %32
    • Using a plastic opening tool, snap open the phone. It should separate into a front piece with the hardware and a plastic backing.
  7. Motorola Droid X2 Motherboard Replacement: passo 7, imagem 1 %32 Motorola Droid X2 Motherboard Replacement: passo 7, imagem 2 %32 Motorola Droid X2 Motherboard Replacement: passo 7, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, remove the white wire at the top of the phone near the camera.
  8. Motorola Droid X2 Motherboard Replacement: passo 8, imagem 1 %32 Motorola Droid X2 Motherboard Replacement: passo 8, imagem 2 %32
    • Remove these nine screws using a T-3 torques. These screws should be 2.40 mm in length
  9. Motorola Droid X2 Motherboard Replacement: passo 9, imagem 1 %32 Motorola Droid X2 Motherboard Replacement: passo 9, imagem 2 %32
    • Using tweezers, removed the white electrical tape on the motherboard.
  10. Motorola Droid X2 Motherboard Replacement: passo 10, imagem 1 %32 Motorola Droid X2 Motherboard Replacement: passo 10, imagem 2 %32
    • Using the plastic opening tool, lift up to remove the connector.
  11. Motorola Droid X2 Motherboard Replacement: passo 11, imagem 1 %32 Motorola Droid X2 Motherboard Replacement: passo 11, imagem 2 %32
    • Using a pry tool, lift the jawbone connector.
  12. Motorola Droid X2 Motherboard Replacement: passo 12, imagem 1 %32 Motorola Droid X2 Motherboard Replacement: passo 12, imagem 2 %32
    • Using tweezers, carefully disconnect the cable connector by pulling the cable out.
  13. Motorola Droid X2 Motherboard Replacement: passo 13, imagem 1 %32 Motorola Droid X2 Motherboard Replacement: passo 13, imagem 2 %32 Motorola Droid X2 Motherboard Replacement: passo 13, imagem 3 %32
    • Use a spudger to disconnect the cable connector.
  14. Motorola Droid X2 Motherboard Replacement: passo 14, imagem 1 %32 Motorola Droid X2 Motherboard Replacement: passo 14, imagem 2 %32 Motorola Droid X2 Motherboard Replacement: passo 14, imagem 3 %32
    • Using a spudger, remove the camera. Lift up the motherboard and slide the spudger under the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Aaron Mak
Membro desde: 10/29/14
658 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 4-3, Miles Fall 2014 Membro de UMass Dartmouth, Team 4-3, Miles Fall 2014
UMASSD-MILES-F14S4G3
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 795
