Ir para o conteúdo principal
Motorola Droid X Motorola Droid X Rear Housing Replacement
O que você precisa
  1. Motorola Droid X Motorola Droid X Rear Housing Replacement, Battery: passo 1, imagem 1 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement, Battery: passo 1, imagem 2 %32
    • Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
  2. Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 2, imagem 1 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 2, imagem 2 %32
    • Once the menu appears, select the "power off" option. Wait until the phone is completely off.
  3. Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 3, imagem 1 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 3, imagem 2 %32
    • Place thumb on the back cover, and push down towards the bottom of the device. Once the cover releases, pull it away from the phone and set it aside.
  4. Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 4, imagem 1 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 4, imagem 2 %32
    • Find the yellow pull tab located in the upper left corner. Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
  5. Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 5, imagem 1 %32
    • The battery has been successfully removed.
  6. Motorola Droid X Motorola Droid X Rear Housing Replacement, Motorola Droid X Rear Housing: passo 6, imagem 1 %32
    • Remove the micro SD card from its connector.
  7. Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 7, imagem 1 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 7, imagem 2 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 7, imagem 3 %32
    • Locate the seam between the back case and the end cover on the top edge of the phone.
    • Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left. Once the cover comes off set it aside
  8. Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 8, imagem 1 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 8, imagem 2 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 8, imagem 3 %32
    • Repeat step 2 on the bottom cover.
  9. Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 9, imagem 1 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 9, imagem 2 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 9, imagem 3 %32
    • Use a T5 Torx screwdriver to remove the screws in each corner of the phone.
    • The screws are very small so make sure not to lose them.
  10. Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 10, imagem 1 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 10, imagem 2 %32
    • Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside.
  11. Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 11, imagem 1 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 11, imagem 2 %32
    • Identify the screw located in the bottom right corner of the battery case. Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside.
  12. Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 12, imagem 1 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 12, imagem 2 %32
    • Locate the seam along the right edge of the phone. Use the prying tool to disconnect the two clips along the edge.
  13. Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 13, imagem 1 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 13, imagem 2 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 13, imagem 3 %32
    • Locate the two clips on the inside of the case and use the spudger tool to detach them from the case. To detach each clip, use the sharp end to press the small, black plastic in the center of the clip.
  14. Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 14, imagem 1 %32 Motorola Droid X Motorola Droid X Rear Housing Replacement: passo 14, imagem 2 %32
    • After the clips are detached, remove the back case and set it aside.
Conclusão
Uma outra pessoa concluiu este guia.
Sam Johnston
Membro desde: 10/03/12
576 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 18-40, Regan Fall 2012 Membro de Cal Poly, Team 18-40, Regan Fall 2012
CPSU-REGAN-F12S18G40
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 941
