Introdução
If you are experiencing having a problem with your LCD or digitizer, follow this installation guide. This is a challenging tutorial, that requires a complete deconstruction of the Droid X. Proceed with caution.
O que você precisa
Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
Remove the screws along both sides of the motherboard using a T3 Torx screwdriver. On some phones this may require a #1 Phillips Screw Driver.
These are T3 screws. I have taken apart about 15 of them in the past week, T4 is too big to fit. Had to use a T3 bit to remove them.
These screws are T4 on my phone, not T3. I stripped 2 screws trying to remove them with T3. Maybe it could be either.
On my phone all screws from Step 15 - 29 were actually #0 Phillip head.
Unscrew the screw at the base of the screen using the T4 torx screwdriver .
18 outras pessoas executaram este guia.
2 comentários
Thank you. This is very helpful.
