Ir para o conteúdo principal
Motorola Droid X Battery Replacement
  1. Motorola Droid X Battery Replacement, Battery: passo 1, imagem 1 %32 Motorola Droid X Battery Replacement, Battery: passo 1, imagem 2 %32
    • Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
  2. Motorola Droid X Battery Replacement: passo 2, imagem 1 %32 Motorola Droid X Battery Replacement: passo 2, imagem 2 %32
    • Once the menu appears, select the "power off" option. Wait until the phone is completely off.
  3. Motorola Droid X Battery Replacement: passo 3, imagem 1 %32 Motorola Droid X Battery Replacement: passo 3, imagem 2 %32
    • Place thumb on the back cover, and push down towards the bottom of the device. Once the cover releases, pull it away from the phone and set it aside.
  4. Motorola Droid X Battery Replacement: passo 4, imagem 1 %32 Motorola Droid X Battery Replacement: passo 4, imagem 2 %32
    • Find the yellow pull tab located in the upper left corner. Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
  5. Motorola Droid X Battery Replacement: passo 5, imagem 1 %32
    • The battery has been successfully removed.
Conclusão
5 outras pessoas executaram este guia.
Alfred Rosen
Membro desde: 10/04/12
117 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 18-40, Regan Fall 2012 Membro de Cal Poly, Team 18-40, Regan Fall 2012
CPSU-REGAN-F12S18G40
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 3,973
