Introdução
Use this guide to replace the display assembly on your Motorola Droid Turbo. If your replacement display assembly does not include a earpiece speaker, you'll need to swap your existing one over to it.
O que você precisa
Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
Remove the four Torx T5 screws securing the lower antenna board to the motherboard.
16 outras pessoas executaram este guia.
8 comentários
This has a bunch of unecessary steps and is missing so,e just kinda bricked my phone thanks to this
Yep. It repeats a bunch of steps, and seems to switch from replacing the display to replacing the motherboard. :(
has anyone ever had the buttons break on this phone? i know on my old droid maxx one little mistake when putting the board in the metal frame was enough to break the volume buttons.
You don’t need to remove the battery from the board…the whole thing comes up as one.
