Introdução
Follow these steps to remove your Droid's broken rear-facing camera.
O que você precisa
Insert a SIM eject tool, SIM eject bit, or a straightened paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Remove the SIM card tray assembly from the phone.
Use the point of a spudger to pry up and remove the coil connector rubber cover.
To reinstall the cover, align the cover and use your finger to push it forward into place.
Using your fingers, carefully remove the black tape from the battery.
Ferramenta utilizada nesse passo:Tweezers$3.99
Use the angled tweezers to lift up the small orange plastic piece near the bottom right corner of the battery.
